Question about Hotpoint Washing Machines
Can i use my hotpoint first edition washing machine with just a cold water feed under sink it has a hot and cold feed but i only have a cold water feed under sink
    Genius:
  • Hotpoint Master
  • 1,585 Answers
U can buy a thing called a y piece from any good hard ware shop
Posted on Apr 30, 2015
    Top Expert:
  • Hotpoint Master
  • 42,991 Answers
You can of course but set the temp control to cold only . normal is not from under any sinks tho . have a plumber come and add a hot water outlet for you
Posted on Apr 28, 2015
SOURCE: hotpoint G-157 washer
get a small putty knife facing the machine insert it about 2 inches from the edge in the little crack between the top and body of the washer push in while lifting the top you should feel the spring that should get the top up but prob you have a leaking tub seal
Posted on Dec 30, 2007
  • 566 Answers
SOURCE: sink adapters for washing machine
hi from uk there is an adaptor for this pupose it is known as a YPIECE which has the facility to have two pipes to connect to one cold fill machine not expensive it may also be called a collector breaching in your location?
Posted on Nov 01, 2008
barkencoa
  • 3463 Answers
SOURCE: WHIRLPOOL AWO/D 5726 - cold water feed only?
Most washers now made in the u/k, are cold fill only, but if the new washer is hot and cold fill, and you only have a cold supply, then it will tell you in the installation guide how to connect it to use it from cold only.
Plz rate my solution.
Thanks.
Posted on Jan 08, 2009
  • 86 Answers
SOURCE: relocation of hotpoint aquarius 1000 washing machine
You don't need hot and cold connected to your machine you can use just cold, but you DO need a supply of some kind to both valves, or your machine will stop when it comes to the rinse cycle and it won't distribute fabric conditioner. Ask for a cold fill adaptor from any plumbers merchants. It looks like a plastic Y the single stem connects onto your cold supply tap and the two hoses from the machine connect onto the top of the Y. The machine will take longer to do a wash but it will work perfectly.
Posted on Jun 21, 2009
SOURCE: whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Posted on Sep 12, 2009
Hot water not coming into washing machine
The solenoid valve that lets hot water into unit is not opening. Check out the valve itself and the timer cam that feeds power to the cam.
Jul 04, 2015 | Maytag Washing Machines
Only hot water is coming . cold water none
Ensure the hose's at the back are in the right places, Could be you or the fitters has put them in the wrong place.
Feb 20, 2012 | Kenmore Washing Machines
Does the wma76 hotpoint need a hot water feed? Is a cold water feed enough?
Hi from retired Englishman in France (it's 21:29!),
If your washer has 2 pipes for feeding water then one is for hot and the other is for cold naturally.
All washing machines have a water heating element in them- in case any hot water supply is not hot enough for its wash.
If you only have a cold tap you will need to purchase a 'Y' connector. This screws onto the cold tap supply (single end) and the hot and cold feed pipes connected to the washer screw onto the other two ends. The machine will now be fooled into thinking it has two separate feeds!
The machine opens the valve for the 'hot' water supply (which of course is cold) and the heats it up to the required temperature for the wash cycle. Afterwards, when the machine requires cold water for rinsing, it opens up the 'cold' supply (which is the same supply as for the hot water!) and is happy.
Hope this answers your question.
John C
Jan 26, 2011 | Hotpoint WMA76 Front Load Washer
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hot/cold cycle works but w/out hot water
I got my washer from a friend and his did the same thing. I have to put the washer on normal for cold water and heavy load for hot water.
Apr 15, 2009 | Hotpoint VBXR1090B Top Load Washer
Inlet hose leaking a top branch
There are 2 versions of the Hotpoint WD640, a cold fill only version, and a hot and cold fill version..
From your question, I conclude you have the hot and cold fill version, which requires a hot and cold fill supply..
I do not understand what you mean by leaking from top banch, perhaps you can clarify.
Thankyou.
Feb 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
Hotpoint BWM129
hi there,
try the following, it may help:
Some washing machines allow hot water to enter only during certain cycles. Others intermittently
allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual
if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
* Is the hot water turned on? If not, turn it on.
* Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Apr 18, 2008 | Hotpoint BWM12 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
