Question about Candy CDC266 Dryer
Screechy Dryer have a similar problem where the dryer screeches when turning and sounds like metal to metal action. Dryer is 2-3 years old but not used that much. From those I have spoken to with the sme dryer they are all have the same problem.
  • maggiesp Nov 22, 2007
    Hoover nextra 8 sensor dryer.
    Makes a screeching noise as it tumbles in one direction only. Fine in the other direction. Please help!
  • neal2 Mar 07, 2008
    I have exactly the same problem - squeaks all the time and screeches in one direction. Any advice on how best to disassemble the unit to access the suspect bracket would be appreciated.
Hi yes i have a candy 6kg tumble dryer. It also screeches when turning. I have taken it apart and found its the bracket at the bottom holding the drum. It has deformed due to the weight of the drum and also the wet clothes added to it increases the pressure on this bracket. Dont know if its a design fault or really how to fix the problem?. Any solutions would be most welcome..
Aprior7
Posted on Nov 21, 2007
Extremely screeching noise when running?
Screeching is the metal-on-metal contact of the drum touching the rear of the unit while
turning - there's a (usually) felt cover gasket over the circular depression at the back of the dryer.
When this wears through (after a number of years/loads), you get the screeching of
metal-to-metal contact.
Problem: friction can heat up the metal so much that the remaining felt gasket material (and/or
accumulated lint or clothing) catches fire.
Fix: replace felt drum gasket.
The Maytag Atlantis MDE6400AY electric dryer has a DuraCushion(tm) dryer drum, so I'm
suspecting the "DuraCushion" has worn out at least at one point in its 360-degree arc.
Jul 07, 2011 | Maytag Atlantis MDE6400AY Electric Dryer
My dryer GLEQ642AS makes a screeching sound, much like metal on metal, when running, but it still dries the clothes. Could a bearing need replacing? It is just 5 years old, but dries 2 loads daily. If the...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 30, 2010 | Dryers
LG Gas dryer has started to make weird screechy(?) noise - almost like the drum is rubbing against something. It's a couple years old - is this a maintenance thing or will I need to replace?
You will need to have the unit checked out by a qualified LG tech to diagnose your problem. Sounds like one of the roller guides may need to be replaced.
Good luck
Sep 23, 2010 | LG DLG5932W Gas Dryer
Dryer screeching and grinding when running
Hi !
The drive belt has become old and hard.
Just change the drive belt and all will be well.
Please don't try to lubricate the belt as may be suggested by many as cheap quick fix.
Regards
Berry.
Feb 01, 2010 | Whirlpool Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
My dryer is making a screeching sound
Pretty cheap part, but the drum gotta come out. The plastic bearing has worn then and it is starting to get metal to metal contact. Open the door and remove the screws inside that are holding down the top. Get the front off. Take the belt loose and yank the drum out. Replace the bearing.
b7661fd.jpgWE3X75
Jan 31, 2009 | Amana DLE330RAW Electric Dryer
Candy condenser dryer cdc 266
Forget purchasing anything, i had the same problem. Slide the lid back and spary the belt with WD40..... noise goes and works a treat and no money spent!
Justin
Sep 20, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
200 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
