Question about Coffee Makers & Espresso Machines
Four month old coffee machine, little used, not producing hot water or steam, the coffee regular is tepid at best
Not producing hot enough water for regular coffee or espresso and certainly not hot enough to produce steam.
  • Mister Danger Apr 28, 2015
    If you've no way to repair it under warranty, you should ask for an authorize service. I had a coffee machine and when a had problems with it, couldnt find way to serve it myself. I believe your problem might be that it was somehow overheated and burned out. You should know how to dismount it.
  • Coffee Maker... Master
  • 5,631 Answers
If your four month old coffee machine is not working as expected, you should claim your warranty where you bought it so it should be repaired.
Posted on Apr 28, 2015
Testimonial: "Thank you, that was my first thought, but wonderful mother recycled packaging, manual and receipt in a moment of tidyness and I think I paid cash..."
    Sergeant:
  • 253 Answers
If you have hard water you may have a build up in the machine... you could try some crl... run it through then two rinse cycles... or buy another of the same make and use the package for a return... out of curiosity did you try another plug in a different loc to see if it isn't a plug problem
My EM 100 is not heating the water up
return it to the place purchased as defective .
Dec 28, 2016 | Coffee Makers & Espresso Machines
Why is Delonghi Perfecta not producing steam to froth milk.Nothing at all happens when cappacino button is pushed
At wits' end DeLonghi Magnifica steam function - Coffee Forum
www.coffeeforums.com/.../9427-wits-end-delonghi-magnifica-steam-fun...
Jun 1, 2012 - While I quite like the coffee it produces, the steam function seems to be ... it with the magic DeLonghi descaling solution, so I'm certain this is not ...
DeLonghi not producing steam Questions & Answers - Fixya
www.fixya.com > Forum > Tags > not producing steam
Ask your DeLonghi not producing steam questions. Get free help, advice ... Ad. Question about Esclusivo Magnifica ESAM3300 Espresso Machine. 3 Answers ...
Delonghi 3500s coffee machine not producing hot water or ...
Dec 06, 2015 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Saeco vienna super automatica coffe maker produces very little coffee and it comes out very slow.
sounds like your pump. When you turn steam knob on, you should hear the pump go bump,bump,bump. When hot water is turned on, you should hear pump run steady.
Jan 07, 2013 | Saeco Vienna SuperAutomatica Coffee...
We have a 4 month old gaggia titanium. Today, the steam wand stopped working. (It makes coffee just fine.) I've cleaned the steam wand. When I turn the steam dial, very little steam comes out and I hear a...
Sounds like the steam wand is getting blocked some where either at the metal end or in the parnello wand if you machine has one at the end of the steam wand, if both of those are clean then try this push in on the steam knob if that works then tap rod assemble or steam valve needs to be replaced, make sure to ask about the stainless steel valve instead of the plastic one.
Oct 06, 2010 | Gaggia Titanium Espresso Machine
My machine has stopped producing hot water. The lights don't even flash to show it's heating up when I switch it on, it just goes straight to ready mode & then when I brew some coffee it comes out...
Either your coffee boiler elements are damaged or the thermostats on there are damaged or tripped, use an ohms meter to check element and thermostats.
May 20, 2010 | Gaggia Syncrony Compact Coffee...
Cannot produce steam
The machine have a separate heating system for steam than hot water for steam. The steam system it might be full of scale. If you hand are good you can easily remove top panel and side panel. You can follow the teflon pipe from the steam wand and it will lead you to the steam solenoid valve and the small copper steam heating system and desasemble it both the valve and small boiler and remove any scale and dirt from it using a wire brush, shurp screwdriver and similar tool. Then poot them back together. You can try the machine with panel removed so if it needs something more to try once more again. One small tip advice. Use your camera and make pictures of everything before desasemble them, then you are safe if you forget about something. In this way you can clean everything metalic that the water pass though.
May 11, 2010 | Saeco Vienna De Luxe Espresso Machine
Frother not working
Unscrew the plastic frother head and make sure that the plastic and the metal ends aren't blocked. Run a descaling solution through the machine.
Jan 11, 2010 | Gaggia 102534 Espresso-Color...
Steam wand shooting water instead of steam
You're supposed to wait for the blinking light to go solid before attempting to steam your milk!
Until then, the water isn't hot enough (it's at coffee-brewing temp, not steaming temp) to produce steam.
Further, after steaming, the water is too hot for coffee's correct brewing temp, and the light again blinks until it has cooled down enough, if you care.
Dec 11, 2007 | Nespresso C190 Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
107 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
