How do I correct a jam error? - Office Equipment & Supplies
    Top Expert:
  • 6,702 Answers
First you have to establish what is wrong. A real paper jam, or a defect sensor, bad cabling or a bad logic board.
Things a user can do is checking if really nothing is in the printer blocking the fear flow of paper or is something is stuck against a sensor. When you made sure nothing is in the printer, don't go further. You need a service centre or a new printer.
Sorry
Posted on Apr 28, 2015
  • 5,631 Answers
If paper keeps jamming, you probably have one of your component in printer damaged. If you are not technician, these kind of issues need specializide knowledge and a so called repai kit so my advic is to take printer to an authorized tech service
HAVING A 13.20.00 ERROR CODE ON A HP 43OO. PLEASE HELP!!
JAM IN TOP COVER AREA
A jam exists in the top-cover area.
A 13.20.00 error message indicates that the printer power was turned on or that the printer attempted to initialize while the pre-feed sensor (PS102), the top of page sensor (PS102) and/or the fuser delivery sensor (PS108) was detecting media.
When the paper feed assembly is installed, the sensor-flag spring must be correctly positioned
for the flag to operate. If a paper-jam error message (13.20.00 JAM) appears on the control-panel
display after you replace the paper feed assembly, verify that this sensor-flag spring is installed
correctly.
Hook the spring over the flag tab (see 1 in Figure). Fasten the paper feed assembly to the
chassis with the flag spring positioned in the hole in the transfer assembly. Release the spring
from the tab on the flag (see 2 in Figure). See figure below.
Verify that the flag is held in the upright position, can freely move, and always returns to the upright
position. If the flag does not move freely, or return to the upright position, an error
message (13.20.00 JAM) will appear on the control-panel display when the printer power is turned
on.
Aug 10, 2011 | Office Equipment & Supplies
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
How to correct paper jam error message when nob
OPEN THE PRINTER .,, THERE MAY BE SOME SMALL PARTICLES OF PAPER IN PRINTER...
Mar 16, 2010 | Office Equipment & Supplies
MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
If there is no jam it is generally a mechanical issue such as...
1. The planetary arm assembly not engaged correctly
2. Ink cartridge/purge switch harness not connected correctly
3. Purge cam switch broken
4. Gear(s) on maintenance unit broken
5. Paper feed motor broken
6. Main PCB defective
I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
You will need to contact your local ASC for repair, find it here.
Thank you for using FixYa! – Don’t forget to rate our service.
Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
I have canon s 300 printer sr no FAYS 12715 some how it does not take paper and green and subsequent yellow light blinking
here are some error code list for you for your s300 printer.
Got this from slayo.com
hope this list will help you find answers to your questions. Goodluck!
ERROR CODE LIST
Error codes are displayed on the monitor of the host computer connected to the printer. For error
code display, keep the status monitor open.
Error Code
Error Corrective Action
1000 Paper out error Load paper, and press RESUME button.
1200 Front cover open error Close front cover.
1300 Paper jam error Remove jammed paper, and press RESUME button.
1401 Head ID error Replace print head, as it has failed.
1403 Head temperature sensor rank error Replace printer, as it has failed.
1405 Head EEPROM error Replace print head or printer, as one of the two has failed.
1700 Waste ink near-full error Replace printer, as it has failed.
5100 Carriage error Replace printer, as it has failed
5200 Head temperature rise error Replace printer, as it has failed
5400 Printer temperature rise error Replace printer, as it has failed
5B00 Waste ink full error Replace printer, as it has failed
5C00 Purging operation error Replace printer, as it has failed
5800 EEPROM/NVRAM error Replace printer, as it has failed
6810 EEPROM print head information error Replace printer, as it has failed
Operator Call Error
Orange lamp
2 times Paper out error Load paper, and press RESUME button.
3 times Paper jam error Remove jammed paper, and press RESUME button.
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Service Call Error
Toggle blinking
2 times Carriage error Replace printer, as it has failed.
4 times Purge error Replace printer, as it has failed.
6 times Internal temperature rise error Replace printer, as it has failed.
7 times Waste ink full error Replace printer, as it has failed.
8 times Print head abnormal temperature rise error Replace printer, as it has failed.
9 times EEPROM error Replace printer, as it has failed.
10 times EEPROM print head information error Replace print head or printer, as one of the two has failed.
Sep 11, 2009 | Office Equipment & Supplies
Paper jam light is continually on and I can't reset.
Did you check for jam in the back (open rear door maybe jam is there)?
Mar 26, 2009 | Lexmark E232 Laser Printer
Printer Error E3
E3 error -
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [Black] or [Color].
The above is direct from the user manual.
If there is no paper jam - look for any small pieces of paper that could be located near the roller sensor.
Oct 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Flashing light
Here is what HP has on the subject of the triangle light flashing:
c00028322.gif 1 - Attention Light 2 - Ready Light 3 - Go Light Figure 2: Printer light key c00028323.gif 1 - Symbol for light off 2 - Symbol for light on 3 - Symbol for light blinking
c00028328.gif Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Figure 8: Paper jam c00028328.gif 13.JJ.NT JAM IN TRAY 1
13.JJ.NT JAM IN TRAY X
The Attention LED is blinking. Check paper loading then open and close top cover.
When there is a jam in tray 1, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored.
When there is a jam in tray X, verify the paper is loaded correctly, open and close the top cover. Pressing GO is ignored. These are the error explanations for just the flashing triangle light, there are many more, but none for just the flashing triangle.
If the light pattern is different let me know (other lights on as well)
-Hope this helps.
May 28, 2008 | HP LaserJet 1012 Printer
Eo-10 code
hi im jules_09,no the copier is not dirty or jammed,if there is a paper jam it will indicate paper jam there is no error code for that,if the copier is dirty you can see it in the print.reset the error code in the program,if the error code is still there checkfusing unit then the optic sensor
Nov 02, 2007 | Canon PC-940 Black and White Copier
Canon s520
The number of orange flashes between green flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action. Two flashes: Out of paper, paper jam or paper feed error Replace the paper correctly and press the RESUME/CANCEL button. If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL button. Three flashes: Paper jam If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button. Four flashes: Empty ink tank One of the ink tanks is empty. Replace it. If all of the above won't help, unplug the printer from the power cable, wait a while, and plug in. If that didn't fix you, I guess it's time to get in touch with canon, or a repair lab you trust. Good luck
May 16, 2006 | Canon S520 InkJet Photo Printer
k24674
