Why would my volume and sound not work? - Computers & Internet
  • wensch00 Apr 28, 2015
    Hi tim dyer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Make, model, Win 8.0, 8.1? of laptop would help.
  • 3,960 Answers
Check any software programs that use the sound system and make sure the settings have not disabled the sound card.
The drivers may be corrupt. Go to your computer support site and look for updated drivers. You may wish to just download and reinstall them again.
If this does not work, go to the control panel, disable and remove your sound card. Then have the computer search for new hardware and load the recommended drivers.
Posted on Apr 28, 2015
  • 5,631 Answers
You shuld check settings in Contrl Panel - Sound and Voice Device
Volume should be high
Check also Advanced Settings if volume low or silenced
  • Computers & ... Master
  • 2,045 Answers
One of the causes would be that you don't have speakers connected.
What are the main cause of a choppy sound when you try to adjust volume
Dust accumulation on the inside of the volume control. With the amp off rapidly change the control from stop to stop several times or until the sound is no longer choppy. If this doesn't work then the volume control will need to be replaced. This trick works for a car radio too.
Jun 20, 2015 | Audio Players & Recorders
Hi, our YouTube.com on our big TV Flat size 51' and using volume and doesn't work volume sound, not working. Need fix it and sound turn on, please.
Volume on TV or receiver or the volume slider within the video?. It seems of one of these does not work you can use one of the others.
Dec 30, 2014 | YouTube Videos
Sniper ghost warrior 2 low sound volume
from the beginning its perfectly work but after that sounds are not coming in any stage if any 1 can pls help me to fix this
Dec 18, 2013 | City Interactive Computers & Internet
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
Sound is not working
There are some possible reasons why the sound is not working. It could be the volume control is in "MUTE", or the right sound card is not selected in the volume properties, or the speaker is defective.
Here's what you need to do:
1. Try to connect an external 2-channeled PC speaker. The computer should recognize the speaker and the sound should be transferred to the PC speaker. If the sound works on the PC external speaker, then you know that the volume control is NOT in mute and the sound card is selected. It means also that the built-in speakers could be defective.
2. If the same problem occur after connecting an external PC speaker, check the volume control, and make sure that the "MUTE" box is not checked. Then adjust the master volume.
* If everything's properly configured, but there's still no sound, check the volume properties under the Control Panel. Be sure that the correct sound card driver is selected. If that did not help, try to re-install the sound card driver.
* And the last option, contact the manufacturer and have them fix it for you.
Thank you and good luck!
Jun 26, 2010 | Acer Aspire 5535-5050 Notebook
Sound output is low nowadays even at full volume whereas before it was ok. I didn't change anything with my computer nor did I change my speakers.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
  • Goto Control Panel
  • Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
  • In device Volume Click Advance
  • Master Volume Control Window will open
  • Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
  • From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
  • From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
  • Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
May 17, 2010 | Computers & Internet
HP Pavillion dv 8000 no sound
check the volumes on sound driver.., also check maybe the master is muted ...if any of these won't work ..check wave volume also ...or reinstall the sound driver ....
look that when you double click the volume in trey system ( bottom right ) you get the full volume manager ..
if those would not fix the issue...uninstall the sound driver and reinstall it ..I assume you have the installation cd ..or the driver on disposal
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Ibm t41 sound not working
Just to try the obvious...
The volume buttons on the laptop underneath the screen work independently to the volume controls in Windows. Have you tried pressing and holding the volume up button and then playing a sound?
Jan 21, 2009 | IBM ThinkPad T41 2373 Notebook
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
Volume
Hi the volume is just a big fuzzy sound. You can listen to anything. Mute button does work and volume adjustment does work. No Sound at all other than fuzzy sound.
Jan 07, 2007 | RCA 32F531T 32" TV
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
