Question about Exercise & Fitness
Where can I get a manual for my Crane heart rate monitor?
To set alarm for heart beat. Can find option to set highest hitrate
What is a normal pulse rate?
A normal resting heart rate for adults ranges from 60 to 100 beats a minute. Generally, a lower heart rate at rest implies more efficient heart function and better cardiovascular fitness. For example, a well-trained athlete might have a normal resting heart rate closer to 40 beats a minute.
Apr 23, 2017 | Cars & Trucks
What is a normal heart rate?
53 to 54 is low, going below 50 is an alarm condition for a EKG monitor - been there, done that!
Jun 05, 2016 | Exercise & Fitness
When does your heart work the hardest
Work is often defined as how much volume or weight is carried, for how far in a given period of time. Examples: Move 1000 Lbs 10 feet in 10 minutes, Now move it 20 feet in 10 min - you've done twice the work. Or, 2000 lbs 10 feet in 10 minutes = twice the work. 1000 lbs, 10 feet in 5 minutes = twice the work.
So, a good measure for a heart would be how much blood is pumped in a period of time. The amount of blood in each beat doesn't really change, this distance is always the same, so how often it happens is a pretty good indicator. Simplified, you could say that the heart does the most work when it beats the fastest. Run for 130 beats per minute is 4 times the work of say, sleeping at 30 beats in a minute. Anything that raises yur heart rate to the highest would be the most work.
Apr 09, 2014 | Computers & Internet
My polar heart rate monitor counts the heart beets for quite a while before it gives me the heart rate as a number it may be up to one hour before it gives me a mumber.
I would go to Polar for a definitive answer but your monitor may not be making a good contact with your body. Therefore the reception of your heart beat is constantly starting over and can't give a reading fast enough. Try adjusting how you wear the monitor and see if it makes a difference. There is a battery in the chest strap also. The new ones have to go to Polar to get replaced unfortunately. That is another possibility.
Nov 02, 2011 | Polar T31 Transmitter and Belt Set
When I took my blood preasure there's a heartbeat sign next to my pulse reading. What does that mean
It shows your heart is till beating and the LCD readout should tell you, your heart rate. Some monitors will also indicate if the heart beat is regular or irregular.
Feb 13, 2011 | Health & Beauty
Setting an hourly alarm on an F5 Polar heart rate monitor.
The only alarms available to use for that watch is your heart rate for exercise and a daily alarm. Unfortunately it does not have the hourly alarm feature. I wish it did I am a personal trainer and hourly chimes would help to keep me on time but my rs200 doesn't have the feature either. Sorry :)
Apr 22, 2009 | Polar Exercise & Fitness
Heart rate monitor reading "lo"
to shutoff HR out of range alarm - when selecting the ranges in the HRM Steup mode - press the START/SPLIT button to toggle the alarm on and off. (use the start/stop button on the pro fitness model). page 14 in my manual
Dec 12, 2008 | Timex Ironman Triathlon Heart Rate Monitor
Polar F6
It sounds like most of you have the heart rate set to display in % of max heart rate. Most Polar products have the option of heart rate in BPM(beats per minute) or percentage of max.
If you look at the display during the exercise, you will see a % icon. You can turn it off in by hitting the back button and go down to HR view settings.
Hope this helps.
Chris @ Polar USA
Aug 02, 2008 | Polar F6 Wrist Watch
Exercise & Fitness Logo
948 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
