Question about Carrier Heating & Cooling
Why does my Carrier A/C, model42QG24-C turn off after 5 minutes, pause, then repeat this cycle again and again?
The red LED on pcb is blinking regularly.
  • 4,350 Answers
This is likely a cycling clutch. It cannot just keep going or everything would just freeze up. Modern systems run until they build enough pressure, then cycle off until that pressure depletes, then starts up again. This nets much lower energy cost.
Car systems do the same.
Posted on Apr 28, 2015
Slinteriors
  • 8617 Answers
SOURCE: Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Oct 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: red led blinks 5 times.
The lamp driver ( Ballast) is faulty
Posted on Jun 18, 2009
Ecollier2012
  • 3459 Answers
SOURCE: It won't come on the red light blinks 5 times then
If the front power light is blinking three times then your TV has a problem with the convergence. You can get the correct replacement parts and full step by step photo instructions from www.TvRepairKits.com
Posted on Apr 18, 2010
  • 8909 Answers
SOURCE: I have a Sony KDS-R50XBR1
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen A2 slightly.
Posted on Jan 19, 2011
Slinteriors
  • 8617 Answers
SOURCE: Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Posted on Aug 05, 2012
Panasonic tc p50g15 tv will not turn on tried 1 minute unplug reset and 20 sec power button hold in. Did not work now no led lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2016 | Panasonic Televison & Video
My Sony KDS-60A3000 randomly turns off, then the red "Power LED" blinks three times repeatedly (not "Lamp LED"). We turn it back on, the process repeats again between 20-60 minutes.
3 blinks of Standby/power LED of Sony sets denotes a SMPS board [G-board] failure. . Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Oct 16, 2016 | Sony KDS-60A3000 60" HDTV
Sir, carrier model42QG24-C comeing to off after 5 mint and then on after some time it repeate this cycle again and again. The red led on pcb is blinking regulerly..
More than likely it is cycling on its low pressure control.. It is an automatic reset device but each time it cycles off, the TDR (time delay relay) keeps it from restarting for approximately 5 minutes.
A steady and rhythmic 'heartbeat' on the circuit board typically means 'normal' operation. If it flashes, stops, flashes, stops etc, it would be giving you a fault code telling you what is cycling it off. You have to count the flashes, slow or fast or a combination of slow and fast and look up the fault codes.
Apr 28, 2015 | Carrier Heating & Cooling
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Mitsubishi WD 52525
GOOD DAY;
THIS COULD BE YOUR PROBLEM:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Sep 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinks
Good Day, michele9886;
There is a long process to go through to isolate the problem, but here you go:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 uFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 uFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C).
Good Luck, Big Irish.
Jun 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
Heating & Cooling Logo
69 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
