Question about Samsung Washing Machines
Model no wa13v5. Why does the pump run constantly when the machine is turned on?
    Genius:
  • Samsung Master
  • 1,585 Answers
Pressoer switch probly
Posted on Apr 30, 2015
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
SOURCE: error code e04 on hoover washing machine
called hoover and they replaced the washing machine
Posted on Jul 28, 2008
  • 9 Answers
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
Posted on Jul 27, 2009
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
Fitting a motherboard to my Samsung WA13V5.There is a terminal under the digital display that does not have a visible matching plug. The motherboard part number is DC92-00278L.
The controller may be applicable to a number of models, depending upon how it is configured. Your washing machine may not use that terminal.
Jun 20, 2016 | Samsung Washing Machines
My washing drained pump burned out. So i replaced it cleande the drum and refitted it all. The problem i have now is my waching machine turnes on and the pump runs as soon as the waching machine is turned...
If you can actually hear the pump running (as in not just hose too low and water draining out), I'd say that the main PCB is shot.
It was probably shot before you replaced the pump (pump burned out from constant running).
These models don't have an overflow as far as I know, unless it is pressure switch based (a possible issue if you did something odd cleaning the drum) remove and reseat pressure switch hose just to be sure.
May 27, 2014 | Washing Machines
My wa13v5 doenst pump water inside
have you checked to make sure the pump isnt jammed?
check the filter.
if you need help to remove the filter and check the pump, let me know
May 17, 2014 | Washing Machines
Samsung wa13v5
The seals in the bottom of the drum where it connects to the gear box is going bad. Changing them out is something that you can do but it is not easy. You pull off the top cap on the agitator and then take off the nut and lift the agitator out, then you can see the seals.
Jan 19, 2014 | Washing Machines
Samsung WA13V5 Fully Automatic Washing Machine. Code error:E4. We bought this machine on 15 August 2012 with Gaurantee of Two Years and a extended Warrantee of 2 years at Game store ILLanga Mall Nelspruit....
when you say water goes out at the same time as going in? have you put the bent in the back of the drain pipe or is the pump pumping it back out ?
Jul 01, 2017 | Washing Machines
Washing Machines Logo
96 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
