Question about Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine
How do I make my machine dispense more coffee?
Setting it at 8 oz gets 4. Is there some way to adjust it? We regularly clean our machine by taking out the brew group and this is the first time it has made such small cups.
    Sergeant:
  • Saeco Expert
  • 223 Answers
Check for leaks.. Sometimes the water goes someplace else when brewing.
Visit our service center.
Service Center for Saeco Gaggia Rancilio Spidem Starbucks Espresso Machines
Posted on Jun 03, 2015
    Habit-Forming:
    New Friend:
  • Saeco Expert
  • 119 Answers
I think is time todecalcify it.
Posted on May 02, 2015
16 oz setting dispenses 32 oz of coffee
Yes this is a problem and it was fixed in 2014.
Jan 21, 2012 | Keurig 5048 My K-Cup Reuseable Coffee...
Tip
How much milk should be added to cocoa ratio in Coffee and Espresso Makers ?
INGREDIENTS CHART CUPS
LIQUID Milk/Water
8 oz.
16 oz.
24 oz.
32 oz.
POWDER MIX with Milk
2 tbsp.
4 tbsp.
6 tbsp.
8 tbsp.
POWDER MIX with Water
4 tbsp.
7 tbsp.
11 tbsp.
14 tbsp.
Thanks and good luck.
on Mar 08, 2010 | Coffee Makers & Espresso Machines
Our coffee maker overflows,coffee grinds get in coffee and overflows.
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. If self-grinding your coffee beans, ensure you are using the correct grind setting for an automatic drip coffee maker. (See instruction manual for coffee maker and/or grinder.)
3. Do not overfill tank with water. Use the marks on the side of the reservoir rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. (See your owner's manual.)
4. Make certain the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
9. Ensure that the coffee machine is sitting level on the counter.
Jul 11, 2009 | Hamilton Beach BrewStation 47214 Coffee...
My grind and brew turns itself off in the middle of brew cycle
3. Do not overfill tank with water. Use the marks on the side of the reservoir as a guide rather than those defined by another measuring method. This is because a "cup" in a coffee carafe is defined as 6 oz, not 8 oz, and in some cases as little as 5 oz as a cup. As such, a 12-cup machine actually produces closer to 9 standard 8 oz cups. (See your owner's manual.)
8. It is extremely important to clean your machine with vinegar or as instructed by your owner's manual at least three times per year, more if your water supply is hard (prone to leaving water rings). A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew a pot of coffee, to produce "off" tasting coffee, or to clog and overrun the filter basket.
May 10, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Water Level
my first response would be to say that you need to put 8 oz. less water in - but that's the obvious and somewhat comical solution. But here's what you need to do:
Take the top cover off (1 std. screw on top) and pull the brown water tray out. turn the unit on its side and clean the heating elements! You most likely have huge calcium deposits in the water tank. Scrape the elements but be careful not to bend the thin wires leading out of the tank (they're paperclip thin and will break if bent back and forth.
After cleaning the elements and tank, remove the drip spout (turn counter clockwise to unscrew) and clean, then clean the red tube hose in the center by pushing a wire (coat hangar thick) down through the middle.
Reassemble and pour two, almost full, pots of water into the tank, this is the default level needed to start brewing. When you pour your third pot in, that is the amount of coffee you will get minus whatever your filter soaks up. Hope this helps - good luck!
F5Tornado
Jul 10, 2008 | Brewmatic Diplomat VI Coffee Maker
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
2-cup won't work
you can try descaleing it again ,then go into
the factory reset program and reset it , I had a
similar problem this fixed mine
Dec 26, 2007 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Incanto Rondo Fully Automatic Coffee Maker Black Espresso Machine Logo
79 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
