Question about BenQ Office Equipment & Supplies
Who had the service remote for a Benq mx720 - BenQ Office Equipment & Supplies
I have a problem with my TV benq dv2860 some of buttons are not function what I have to do bt I have not a remote?
Check and replace the micro-switches behind all front panel buttons. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Mar 18, 2015 | BenQ Televison & Video
How do I reset forgotten password on Benq DV 2680 lcd tv?
DID YOU SET THE PASS WORD YOUR. OR DID YOU JUST USE THE ONE THAT CAME WITH THE TV. YOU COULD LOOK FOR A RESET BUTTON BUT IT BY BE IN THE SETTING OF YOU TV. GO TO REMOTE GO TO SETTING, TRY 0000 OR 1234, IF NOT THOSE YOU SHOULD TRY IN FIGURE THAT NUMBER. MOST TV'S WILL NOT LET YOU RESET PASS CODE UNTIL YOU ENTER THE RIGHT ON FIRST. THE BEST ADVICE I CAN GIVE YOU RIGHT NOW IS TO CONTACT THE MANUFACTURE CUSTOMER SERVICE TECHNICAL SERVICE PERSON AND HOPE THEY HAVE A WAY TO PLUG USB DRIVE WITH SOFTWARE THAT WILL RESET PASS WORDS,
Mar 01, 2015 | BenQ Computers & Internet
How can i set up for my BENQ tv
If you are using a Benq remote, connection should be automatic. If you are using a programmable rermote and code 294 does not work, try the code search feature to hunt through all available codes and find one that works. If a thorough search through all codes stored in the remote does not result in anything, you may have to try a different programmable remote. All programmable remotes do not contain the same codes.
Nov 17, 2014 | BenQ G2010WAP 20.1 in. LCD TV
BENQ 720 FACTORY SETUP
www.benq.us/product/projector/MX720
Aug 26, 2014 | Office Equipment & Supplies
BenQ W1070 projector and ONE FOR ALL URC-7140 what code to use ?
BenQ remote codes may be unique. You can try using the code search feature of the remote but you may not find one that works.
Jul 11, 2014 | BenQ W1070 2000 lumens 1080P Full HD 3D...
Control remote replacement v42p tv
Sir,
I am asking of Benq Model no - v42p of factory reset service code.
Aug 15, 2013 | BenQ PB6100-REMOTE
My BENQ monitor blacks out
Use the remote to access menu mode
then try inputs through the remote
Jun 16, 2009 | BenQ FP71G 17" LCD Monitor
What is the manufactures remote code for the BenQ DV3250 TV??
I had exactly the same problem, no code could be found. I solved this problem by bying a: "One for All" remote, which is a learning remote. By following the instructions, (which are easy), you place the original BenQ TV remote face to face with the One for All remote, and you can transfer all the necessary buttons to this All for One remote. You can also control all your other remotes.
Good Luck.
Jun 03, 2009 | BenQ DV3250 Television
BENQ VA321 REMOTE CONTROL
Hi there
A universal remote would do the job , as long as you make sure that the Universal Remote can learn IR codes which it uses to control the Projector.
Sep 25, 2008 | BenQ 98J2032B01 PE8700-REMOTE Projector...
Reset after lamp replacement
benq mp610. press EXIT button for five sec. you see counter hrs. then press AUTO button to reset
Oct 13, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
52 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
