Question about Carrier Heating & Cooling
My carrier split ac model 42QG24-C is comes to off after five minits and then come to on after some time and it repeate this cycle again and again please help and guide me .
  • J Rosado May 02, 2015
    Hi farooq bhatti, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    - Does the indoor fan shut off as well? Set your fan to 'on' instead of auto, the compressor may short cycle (cycle on and off) continuously if it has a problem but the blower should not
  • 659 Answers
SOURCE: carrier split 42G250HF-1(indoor unit
I'm not sure exactly what unit you have and what controls you have installed on the unit. But....there usually is a flash code schematic on the unit. Usually on the inside of the blower compartment cover. This should tell you what is wrong with the unit. It could have a low voltage short somewhere and is loosing the call for cool. So the answer can be a possible yes to your question but without knowing the flash code, it's hard to tell from my point of view. You might end up calling a service professional out to check it.
Posted on Mar 30, 2009
SOURCE: Furnace comes on for 1 min then kicks off, repeats this cycle
MY FURNACE WOULD RUN FOR ABOUT TWO MINUTES , THEN THE BURNER WOULD GO OUT BUT THE BLOWER WOULD CONTINUE TO RUN , LONG ENOUGH TO COOL THE FAN LIMIT SWITCH DOWN , THEN IT WOULD START THE PROCESS ALL OVER. WHAT FIXED MY PROBLEM WAS THE SECONDARY HEAT EXCHANGER THAT IS LOCATED JUST ABOVE MY BLOWER MOTOR WAS PLUGGED WITH DIRT , WHICH RESTRICTED THE AIR FLOW , CAUSING THE FAN LIMIT SWITCH TO REACH 200 DEGREES AND SHUT THE BURNER DOWN . YOU'LL HAVE TO TAKE THE BLOWER MOTOR OUT TO GET TO IT , BUT MY FURNACE IS RUNNING PERFECT NOW
Posted on Jan 11, 2010
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
SOURCE: Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR
i want know that how can connection wiring of indoor panel and out door panel 0f carrier 42qg24-c / 38qg24-c ?
(i need wiring diagram)
Posted on Jul 06, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My split type 2.5hp carrier express ion shuts off
How many times is the light blinking? Also is the light red, yellow or green? The light blinking is telling you exactly what has failed.
(# of RED blinks first)
1 High Pressure Protect
2 Indoor coil freeze protect
3 Low pressure protect
4 Compressor discharge protect
5 Low pressure/Overcurrent protect
6 Indoor-outdoor communication error
8 Hi-Temp protect
10 AC Voltage Low
Each of these has maintenance required steps to resolve the errror. Let me know how many blinks your getting...
Kelly
Posted on Apr 25, 2011
What is the tonnage of a carrier furnace model number 58gp100-2
It can handle five tons, or a 60000 btu ac. Tonnage is a measurment for the ac, 1 ton-12000 btus. The ac dose the cooling. the furnace simply blows the air, so if its a good furnace, and sized right, no need to replace it. Simply add the split system to the existing furnace. If you want the tonnage of the ac size, let me know your homes squarefootage, age, condition. Do NOT include the basement in the sq. ft.
Apr 07, 2015 | Heating & Cooling
Ac works but when compressor cycles, it wont come back on until i rev engine to 4500 to 5000 rpm's and compressor kicks back on until it cycles again. i have to repeat reving engine every time com
you need to check the pressure of the system if the system is a little low on freon it will cycle more also if the cooling fan is not working the pressure will raise and also shut off
Aug 17, 2012 | 1997 Nissan Pickup
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
My split type 2.5hp carrier express ion shuts off (including the condenser) after five minutes of running, the indicator light blinks during this time...it restarts again after awhile, then shuts off again...
8 Hi-Temp protect
10 AC Voltage Low
Kelly
Apr 25, 2011 | LG Heating & Cooling
Carrier 42QG24-C / 38QG24-C 24000 BTU SPLIT AIR CONDITIONER i need to know how to program the remote control.
Feb 09, 2010 | Carrier BCA101R Air Conditioner
Ffurnace not working. led flashed five times then off and repeat the five times. reset the unit by switching bkr off and back on. led is steady, but no ignition. do smell gas and can see gas meter respond...
If it's a hot surface ignition system I'd guess it has a bad ignitor from your clues. If however it's a spark ignition system I'd guess it has a bad ignition control.
Mar 17, 2009 | DCS Large Appliances Outdoor Heaters
Compressor runs for a sec and cuts off for about couple of minites and runs again
no changing or turning the plug, wont make no difference to the compressor, it sounds to me like your compressor is overheating. have you clean the condenser?? they get durty.
Apr 03, 2008 | Carrier XHC101D Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
