Question about Miscellaneous
Where can i find that spares
Its for a honda its a 1982 model its the black strip that comes's on the side or the car,i don't know what you call it
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 73 Answers
Look for Japan surplus.
Posted on Jul 24, 2015
2 Suggested Answers
SOURCE: passenger side window
Same thing happened to me. There is a button to the left lower side of the steering wheel that I pushed while cleaning the dash. Drove for a year without being able to raise or lower the passenger window. Accidentally pushed it again one day and voila! passenger window now works. I think it has a red X on the button and it isn't real clear what it's for. Give it a try!. Mine is a 2003 Celica.
Posted on Jun 19, 2010
What else would I need to do the timing chain
What country are you in? is their a Honda Xr club in your country?
XL's where just the 'Farm version' of the XR.
I can search/source the parts etc, let me know what you need etc.
Cheers, good luck
Oct 05, 2015 | Honda Motorcycles
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1980 - 1982 Honda Civic...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1980
1981
1982
STEREO WIRING COLOR CHART:
Constant Power: White/Blue
Switched Power: Yellow/Red
Ground: To Chassis Metal
Illumination: N/A
Dimmer: N/A
Antenna: Drivers Side Pillar
Left Front (+): Red/Green
Left Front (-): Brown
Right Front (+): Blue/Green
Right Front (-): Gray
Left Rear (+): Red/Yellow
Left Rear (-): Brown
Right Rear (+): Blue/Yellow
Right Rear (-): Gray/White
NOTES: - none -
Additional Accessories:
Metra Brand Dash Kit: n/a
Metra Brand Wiring Harness: 70-1388
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Accessory: Yellow - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Green/Black - (-) Hatch Pin Switch
Parking Lights: Red/Black - (+) Light Switch
Hood Pin: n/a
Factory Disarm: n/a
Door Trigger: Green/Black - (-) Pin Switch
Door Lock: Green/White - (-) Driver's Kick Panel
Door Unlock: Green/Orange - (-) Driver's Kick Panel
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : n/a
NOTES: 4000PPM
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 01, 2010 | Honda Civic Cars & Trucks
I have tojumpstart then dash comes on/ihave a burnt wire or switch,don,t know where to look
i think you burn out fuse to starter and dash
remove side cover on kickstand side
check fuse. it looks like a thin metal strip under two screws and has a cover plate.
if burnt
should have a replacement one right there.
check all fuses
Sep 12, 2014 | 1984 Honda GL 1200 Aspencade Gold Wing
How do I change the air filter in my 1982 Honda Silverwing GL_500? The filter didn't have instructions.
Take off your right side cover (part #9) http://www.bikebandit.com/houseofmotorcycles/1982-honda-gl500-silver-wing-500/o/m9607#sch409523 and you will see the air intake horn on the side of the air box. Turn the cover counter clockwise and pull the air filter straight out the side of the air box. The cover you turn is part # 2 on the diagram. http://www.bikebandit.com/houseofmotorcycles/1982-honda-gl500-silver-wing-500/o/m9607#sch409523
Jul 23, 2011 | Honda Honda Glamour Motorcycles
1982 Honda CB7, 750 - I'm told I need a stater -
Babbitts has OEM stators in stock. Roughly $256.00. You may also Google motorcycle salvage honda and see what you can find. Please rate my answer. Thanks. www.babbittsonline.com
May 25, 2011 | 1982 Honda VF 750 S
My honda odyssey touring does not have a spare tire. We bought this as a brand new car. The first time i had a flat tire we checked everywhere in the car even with AAA service help and we were not able to...
2005 Honda Odyssey TOURING models originally came with Michelin PAX run-flats and eliminated the traditional dough-nut spare. If your van no longer has run-flats (look at the tire size) then your van has already been De-PAX'd...count your lucky stars because PAX tires run about 300 a tire plus!!! If you have been De-PAX'd then you will need a donut spare (T135/80D17) this goes into the spare tire space located behind the 3rd row of seats. this Site has everything you will need for the spare http://www.hondapartworld.com/1534_SPARE-SHJ
Mar 23, 2011 | 2006 Honda Odyssey
Need electricl dia. for 1982 goldwing honda mortorcycle
Visit the Honda Riders Club of America. Join for a couple bucks and you can view the service manual for your model. You can even download and print it I believe. In your case, membership is a good investment. I believe a 25 year old document will otherwise be hard to come by.
I hope this helps you
a
Oct 10, 2009 | 1982 Honda GL 1100 Gold Wing
Fork oil quantity
I have a 1982 CB750C the manual says the quantity is the same for all bike before 1982 it says 6 ounces for the air assist fork models. this is from a clymer manual i recently bought. Highly recommend getting one
Jun 27, 2009 | 1983 Honda GL 1100 Aspencade Gold Wing
Honda civic 1992 twin carburators model.
I dont know where do you live, but honda civic 1992 don use carburator, they are fuel injection, you can have coolant temp sensor problem, or map sensor problem, run diagnose jumping the diagnose wires loated in the passenger side, kick panell close to the door wall, better get the repair book in the parts store to locate the conector ,and read how you can run the diagnosis
Oct 05, 2008 | 1992 Honda Civic
Replacing Passenger Side Door Moulding
First are you talking about the weather stripping that goes around were the door close into? If this is it, just pull off the old one clean the area good, brake clean works very well. then put the new one in place I recommend some contact cerment here and there to keep it in place so its not flopping all over you. If this is not the black strip please let me know which piece it is.
Aug 21, 2008 | 2000 Honda Civic
Miscellaneous Logo
16 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
