Sc 541 in sp 100
Fualt code sc541
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 150 Answers
THIS QUIESTION NOT CORRECT , SC 541 ERROR IS SCANNER ERROR PLAESE CHEQUE THE SCANNER CABLE
Posted on Apr 28, 2015
drichards
  • 87 Answers
SOURCE: Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Posted on Apr 01, 2008
SOURCE: error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Posted on Nov 10, 2008
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
SOURCE: ricoh aficio 3045 error code sc 541
Fusing thermistor open
Fusing thermistor disconnected
Fusing thermistor connector defective
Fusing thermistor damaged or warped
Fusing temperature –15% less than the
standard input voltage.
Change the thermistor.
Posted on Dec 07, 2009
  • 114 Answers
SOURCE: code error SC 541 ricoh aficio mp2550
SC541 is a Fusing thermistor open (center) The temperature of the hot roller remained below 0oC for 5 sec at the center of the hot roller. Fusing thermistor out of its position because of incorrect installation. Fusing thermistor disconnected or defective power supply not within rated range (15% or more below rating). Try cleaning or replacing the thermistors and reset code in service mode.
Posted on Mar 21, 2010
Service call sc541
change the fusing thermister
thanks
Nov 26, 2015 | Ricoh Aficio SP 3510SF
Three in one copy, fax and printer ricoh sp100sfe is showing error sc541 .how do i clear it
this was translated from Russian by Goggle so.....read it carefully they construct sentences differently than we do...
SC-541: The temperature of fuser defined thermistor
is less than 0 ° C for 5 s.Temperatura fixing reaches + 15 ° C (
center) or + 12 ° C (at the edges) 5 times for 2 min after the lamp Fuser.
Login to the service-yellow, 107 red (hold 3 seconds) 5-810-1.
Enter SP 5-810 (SC code reset) and select "1". Then hold down the Original type key and the OK or! key at the same time (this does not require the main switch to be turned off and on).
If the reset - does not help, clean the thermistor!nail varnish cautiously take off with it, only - film does not tear ... can also cautiously cloth soaked in acetone scrub
Nov 07, 2014 | Office Equipment & Supplies
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
My aficio 1515 have a code SC541
sc 541 is a fusr error. please email me on ronils_singh@yahoo.com.au so i can email you a procedure to reset the code.
Sep 28, 2010 | Ricoh Aficio 2015 Copier
FORM SIMULATION MODE? FOR CANCEL CODE SC541
Your fusing (Hot section) unit needs to be reset or replaced
Aug 14, 2009 | Ricoh Office Equipment & Supplies
Error SC541 ON NRG MP 1600L
First try entering into SP mode by pressing:
Clear button>1 0 7> and press and hold the Stop button for 3 secs. Then switch off and on the copier.
If SC 541 code is still there, check the following in the fuser unit:
  • Fusing thermistors defective or out of position
  • Thermostats open circuit
  • Power supply board defective
  • Loose connectors of Fuser unit.
Feb 26, 2009 | Gestetner DSm615 Digital Imaging System
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
SC 541
Take the fuser out and clean under the thermistors, and reset the code by entering test mode ( turn off printer hold down online and escape as you turn on printer selece 2 engine go to sp5-810 and reset this.
-Carl, please let me know if this helps.
Jul 30, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
90 people viewed this question
jasbo
jasbo
