Question about Memphis Car Audio & Video
I have a memphis mcd 1000. It started smoking and blew both fuses. I replaced the fuses now when I hook power to the amp sparks real bad like the power and ground are touching
    Sergeant:
  • 228 Answers
I hate to tell you this, but you have something major. Shorted. Check your wires and conections with a meter. The bad news. Is your amp may be a goner.
Posted on May 03, 2015
The Marv
  • 72 Answers
SOURCE: Please help
Check to make sure you speaker has not shorted. Try a different speaker. If this is not the case you could have an internal shorted transistor inside of the amplifier. or in some cases both. If it is in the amp and you are comfortable working on the amp remove the cover and along the side connected to the heatsink. You will find the smps and the output transistors. use an ohmeter and check across the three legs one way you sould get one reading and if you flip the leads you will get another. if you encounter no resistance, no matter which way the leads are placed. That transistor will probaly need to be replaced. But check the speaker before you do anything. and the wires going to the speakers.
Posted on Aug 03, 2006
ampman
  • 98 Answers
SOURCE: AMP not workin
yes defrinately sounds like it needs repair. I would love to repair it for you or possibly buy it as-is. email me at bigmikeselectronic@comcast.net and i will do what i can for you.
Posted on Nov 27, 2006
  • 109 Answers
SOURCE: Keep Blowing Fuses
Sounds like the amp is shorting somehow. You are obviously shorting out somewhere between the battery and the amp. Are you sure you grounding location is a good one? is the fuse blowing only when you turn the stereo on? Something is not hooked up correctly.
If the fuse at the battery is blowing then it's a short.
If the fuse on the amp is blowing then its probably a bad amp.
Posted on Jun 19, 2008
pjstanley
  • 185 Answers
SOURCE: ROCKFORD FOSGATE T-3000bd POWER AMPLIFIER
u probley just cooked the amp cant tell u how much and i say that for every body so dont be stupid asking q. and a's like that
Posted on Oct 31, 2008
  • 15 Answers
SOURCE: When I hook power to my amp the protect light comes on.
when connecting or disconnecting 12v power dont let the screwdriver touch the screw in terminal and side of amp at same time it causes a short in amp send it in to the factory or it could be the internal battery is burnt out from crankin it to loud
Posted on May 22, 2009
Blew 80 amp fuse in 86 toyota pickup,replaced it, now I have no fuel or spark
check all the fuses when you do that they blow out more than one fuse
Apr 23, 2012 | Cars & Trucks
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
I have 2 15 in memphis speakers and a 1200 watt xplod amp...all of a sudden my head unit fuse blew so i changed it,it blew again, so i used a 15 fuse instead of a 10 so now the head unit works but the...
Sounds like a grounding issue. Check all groundings from the amp and make sure the ground and a hot wire is not touching. If not, it is probable a bad amp or your reduction in ohm rating is probably too low for the speakers. Amp to speaker ratio.
Apr 14, 2011 | Car Audio & Video
I have a new memphis pr 1000 and when u put power
Sounds like a grounding problem. Possibly internal.
Feb 17, 2010 | Car Audio & Video
Fuses keep going out put new fuses and the same problem occures.
IT'S YOUR AMP I HAD A MEMPHIS 1200 WATT AMP AND IT DID THE SAME THING I FORGOT WHAT THE PART WAS CALLED BUT IT'S WHERE YOU PUT YOUR FUSE'S IN THE PROBLEM IS FROM THE INSIDE OF THE AMP. IT COST ME $200 SO IF IT'S WORTH IT FIX.
May 03, 2009 | Diesel Audio NS-1000 Car Audio Amplifier
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Oct 27, 2008 | Car Audio & Video
How to adjust
hello . i think i can help ...u want to set your crossover points to 125Hz and for the subs if u want deep bass set them to 50 to 80Hz...try them and see what u like best
Jun 20, 2008 | Sony XM-2200GTX Car Audio Amplifier
Car Audio & Video Logo
173 people viewed this question
Top Memphis Car Audio & Video Experts
Tygh Duval
Tygh Duval
Tom Chichester
richard foulk
Are you a Memphis Car Audio and Video Expert? Answer questions, earn points and help others
