Fills up with water but does nothing else - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Unplug for 15mins retry
Posted on Apr 30, 2015
Fills with water will not run no motor sound nothing
top load or front load .might be the lid switch /door switch . or the control board make,and model usually helps us help you
Oct 24, 2015 | Kenmore Washing Machines
Crosley washer fills with water than does nothing lid switch is good
Hi - Since you have already confirmed that the door lid strike is in good condition, does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Nov 19, 2012 | Washing Machines
How to repair a new washes etw4400 when it fills with water and nothing else happens
You will have to drain the water first by putting your drain hose into a bucket, out a door, etc, or use a shopvac (take clothes out first). This washer has a broken agitator belt. If it is new, call a repairman as should be under warranty.
Jun 16, 2012 | Estate ETW4400VQ Top Load Washer
Hello Expert Fixya Person. My machine fills with water when I start the wash then does nothing. I end up emptying the water from the tube at the lower right hand bottom of the machine. If I don't empty the...
Hi dear.Your machine's motor brushes,that needs to be change.If you are not handy call service department.If you are,you need to get acces the motor.There are two carbon brushes back of the motor on one of each side.By the time they get worn off & lost the contact on motor "rotor"Take them off & replace with the new ones.Also check the harness.I hope that helps.Thanks.
Aug 31, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The timer works and fills with water. the belt is
So you start the easher it fills with water but does nothing else is that correct? If so It is possible that your door switch is faulty
Sep 08, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Machin fills with water,washes and then fills again
hotpoint wma turn off the power and you are looking for the presure w
switch and chamber , the switch is at the back of the soap draw by the valves on the left hand side there should be a hose going into it take it off and blow through it if nothing happens pull the machine out and at the bottom of the back there is a white plastic cover take it off look for the sump hose and on the side of it there is a whit plastic tube this is the presure chamber clean it out might be blocked
Jun 27, 2009 | Hotpoint WMA64 Front Load Washer
Water fills but does not agitate or spin
THIS UNIT HAS A DOOR SAFETY SWITCH WICH ALLOWS WATER TO COME IN BUT NOTHING ELSE TO HAPPEN IF THE DOOR IS OPEN I WOULD START BY CHECKING THIS SWITCH.
Nov 29, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
