Question about LG Washing Machines
LG toploader 6.5kg wtf 6500 stops working after a short while, what is the solution for this
  • tom cassidy
    tom cassidy Apr 29, 2015
    Hi Ali Waheed, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
AE ERROR PROBLEMS
AE error code : base sensor has sensed water.
Dec 07, 2015 | LG WT4801CW 27" Top Load Washer with 3.7...
Nokia 6500 classic got wet now dead even after
try a new battery, you may have shorted out old one, if this doesnt work then you shorted out phone, needs to be repaired by a phone tech.
Aug 18, 2009 | Nokia 6500 Classic Cellular Phone
LG TOPLOADE WSHINGMASHINE WF-T7014PP
call 0800 54 54 54
or visit them in Barbra Road in Isando neer the N12 crossing
Jul 16, 2008 | LG WFT1071TP Top Load Washer
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Nov 22, 2007 | LG WFT1071TP Top Load Washer
LG Toploader Wash cycle won't work
check for the water seal first if it is leaking! if it does, then it might just be the one causing slipping.
Nov 13, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
