Question about Sigma Cameras
Disponen de zapatas para flashes Sigma - Sigma Cameras
Como puedo aser para k se apage el chek trans de mi isuzu trooper 93
Check transmission lamp? my Isuzu trooper Apage 93 And disconnected plug, and even blinks stills
the lamp means transmission errors.
IS this car an automatic transmission.?
if yes, then some flash the OD lamp and others blink a check transmission warning lamp.
we find the car has TCM ? transmission brain and we scan it.
this old car has flash codes for TCM.
we insert the jump to the TCM DLC connector and it flashes out error codes, we write down and use to fix car.
translated
Compruebe la l?mpara de la transmisi?n? mi soldado Isuzu apage 93 Y enchufe desconectado, e incluso parpadea alambiques
la l?mpara significa errores de transmisi?n.
Este es un coche de una transmisi?n autom?tica.?
en caso afirmativo, a continuaci?n, algunos de flash El indicador OD y otros parpadear una luz de aviso de transmisi?n cheque.
Podemos encontrar el coche tiene TCM? cerebro de transmisi?n y escanearlo.
este viejo coche tiene c?digos de flash para TCM.
insertamos el salto al conector DLC TCM y destellos a cabo los c?digos de error, escribimos y usamos para fijar coche.
Oct 12, 2015 | Isuzu Cars & Trucks
Grinding noise during braking
Make sure the axle nut is tightened to the proper spec. It should be in the area of around 220 ft lbs. The axle nut is what sets the pre-load of the bearing and improper tightening can damage a new bearing very quickly. Also, make sure the rock guard around the rotor is not bent out of place. Often times when a wheel bearing is replaced, the rock guard is distorted and can rub against the rotor when the brakes are applied. Pay close attention to the area around the lower ball joint. Foreign material on the brake pads can also produce a noise.
Apr 23, 2014 | 2007 Nissan Quest 3.5 Minivan
Ruido en el freno trasero derecho de un toyota 2003
Es util saber si tienes frenos de tambor o de disco. Si es de tambor tienes que revisar el desgaste de las zapatas y tambien ver que este bien armado. Puede haber polvo o algun material que no debe estar alli. Si son discos puedes ver el desgaste a travez del caliper. Espero que esto sirva.
Apr 16, 2014 | 2003 Toyota Corolla
Varadero 2008 no para de parpadear la luz del abs @
Hola, An?nimo para este escenario, necesitar?s el manual de servicio, la ficha de piezas y el manual del propietario si no puedes encontrar la mejor herramienta que hayas comprado para tu Honda, no desesperes, por tan solo cero $ 0 puedes descargar otra. Para obtener m?s informaci?n acerca de su problema y las valiosas descargas "GRATUITAS" que necesitar? para ver o imprimir, haga clic en los enlaces azules a continuaci?n. Buena suerte y que tengas un d?a maravilloso. Abs light flashing traction control turns on
ABS light flashing
Honda Varadero MK1 XL 1000 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
https://tosfauclimti.files.wordpress.com/2015/07/honda-varadero-xl-1000-owners-manual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2012 | 2008 Honda XL 1000 V Varadero
Tengo un receiver denon avr1609 y quiero restaurar los valores de fabrica como puedo resetear
uno de los tres por debajo de las soluciones de trabajo para que el receptor
1. Para reiniciar el sistema, a su vez el receptor apagado por el peque?o bot?n on / off, no el bot?n de espera grande. Mientras que fuera de noche y pulse el bot?n directo puro, a la vez y sigue tomando con su mano derecha mientras presiona el peque?o bot?n on / off con la izquierda. Ver? el flash men? del receptor. Cuando lo ves flash dejar ir de la noche y botones de acceso directo puro y el receptor se reiniciar? si mismo a la estaci?n de radio 87.50.
2. Pulse el bot?n "Power" al mismo tiempo presionando el bot?n "Standard " y "Simulaci?n DSP" en el panel frontal de su receptor Denon. Estos botones tambi?n pueden estar ocultos debajo de un panel tir?n en funci?n del dise?o y el modelo de Denon que se utiliza. Algunos modelos de Denon requieren diferentes combinaciones de bot?n que se pulsa simult?neamente mientras se presiona el bot?n "Power", como el "Modo Surround" botones. Algunos modelos de receptor Denon no proporcionar? las instrucciones de restablecimiento en el manual del usuario, para encontrar las combinaciones de bot?n derecho debe ponerse en contacto Denon.
3. Pulse el bot?n "Power" para apagar el AVR-
Pulse el bot?n "Power" al mismo tiempo la tecla "altavoz A "y "Speaker B" botones. Espere a que el AVR-788 a la pantalla comenzar? a parpadear a una velocidad de alrededor de una vez por segundo.
Suelte los botones despu?s de la pantalla comienza a parpadear. El AVR-788 es ahora restablecer la configuraci?n predeterminada de f?brica.
Mar 15, 2011 | Denon AVR-1609 Receiver
I am looking for a manual for a Singer Magic Steamer 7.
TENGO UNA PLANCHA MSP7, LA CUAL PRENDE PERO NO CALIENTA, AQUI EN PARAGUAY NO HAY QUIEN ARREGLE, NECESITO SABER SI DISPONEN DE PLANOS ELECTRICOS Y DESPIES DE LA MISMA, DESDE YA MUCHAS GRACIAS.
MI MAIL ES:
sabatel2010@hotmail.com
Dec 30, 2010 | Singer Electronic Steam Press
Sale un mensaje flash eror! please backup the data
para dar formato a un jugador concreto que primero debe ir al menú de opciones y después ajustarlo a tus preference.Backing es muy sencilla, sólo encontrar el tamaño de la tarjeta de memoria y luego empújelo y copia de datos y seleccionar el tipo de card.Hope it helped
Dec 16, 2009 | iLO (2 GB) MP3 Player
Sigma 28 80 mm mini zoom macro
No se como un lente puede romper el anclaje al cuerpo de la camara, pero si en verdad se rompio, deberia llevarla a una tienda fotografica para que la arreglen. Le queda tiempe en la garantia?
Mar 27, 2008 | Sigma 28-80mm Mini Zoom Macro Lens
Cameras Logo
108 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
