Why don't my top loader drain out the water during and after the washing cycle,all filters and pipe are open but still not draining
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage
Posted on Apr 29, 2015
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
IFIXALL
  • 868 Answers
SOURCE: LG Top loader not draining water to rinse and spin
YOU NEED TO CHECK THE WATER PUMP,SO LAY THE MACHINE ALL THE WAY DOWN ON ITS FRONT,NOW YOU HAVE ACCESS TO THE PUMP.Remove any debris that may be lodged inside of it.
Posted on Jun 09, 2008
futureloginn
  • 734 Answers
SOURCE: Daewoo Top loader washing machine water wont drain...
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Nov 01, 2013 | Zanussi Washing Machines
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
The water isn't draining before or after the rinse cycle, basically creating a backlog of water that (I think) is also causing my belt to burn a little during the spin cycle. What can I do to fix this? ...
You will have to check the drain pump filter - usually situated at the front bottom corners of a Front Loader, and at the back of a Top loader. It is a small compartment you can open. Remove the object or sludge that is causing the impeller of the drain pump not to turn. If no object or sludge is found, or removal does not fix the problem, then I'd suggest you replace the Drain Pump.
Hope this helps.
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | Kenmore 98702 Stacked Washer/Dryer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
