Question about Exercise & Fitness
My crazy fit machine just stopped then sparked from plate and blew my house fuses. what could b wrong
    Sergeant:
  • 283 Answers
Hi Jacqueline, Hmm I'm thinking its carput I'd be buying a new one or send it in to get fixed. Cheers Greg.
Posted on Apr 28, 2015
  • 991 Answers
Dead short in electrical wiring, remove plug from wall socket. Need someone capable of testing electrical wiring.
Why doesn't it fill and perform any wash cycles?
If you are saying that a house fuse blew out then the question is why did that happen? If the washer shorted out and blew the house fuse then you have to work on the washer to see why. It might have been the transformer in the washer power supply. If the fuse blew during a storm then it might be lightning damage and that would mean replacing the power unit and the computer in the machine.
May 24, 2015 | Washing Machines
Life Fitness 4000 repeatedly blows outlet circuit breaker
If there was a fuse in the treadmill it certainly wouldn't cause your main circuit breaker to blow. It sounds like the motor burnt out and shorted- which is causing your house circuit breaker to blow. There is a chance that the ball caused some other damage that is creating the short but my bet is on a burnt out motor. You would need to disassemble the unit and test for short circuits to verify.
Mar 04, 2014 | Life Fitness Lifefitness 4000 Treadmill...
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
Aug 30, 2010 | Sport & Outdoor - Others
The dishwasher suddenly stopped.The fuse cut out also.
I blew air bcakwards into the drain hose... then later when the machine began to operate I cleaned out any food debri in the strainer and used the special dishwasher cleaner thru the machines normal cycle.
Dec 31, 2009 | LG Dishwashers
Where to look for the short that keeps blowing the fuse
There are a bunch of places it could be. Look for anywhere the wires go over, around or under the frame, trans bell housing. It could be a component that is bad causing a short also. I would look for a bad wire short to ground though as this is the most likely cause.
Jun 02, 2009 | 1991 Jeep Wrangler
I am trying to problem solve for dishwasher that is properly installed and is not working or even responding to being hooked up electrically. My husband tried to wire it and unfortunately wired it...
no matter what brand it is the unit must have been hooked up power to ground to make a spark when turned on.
they dont have a fuse to protect them, but what may have happend is you could have shorted out a door switch.
be sure that you hae the wiring correct now and that your house fuse or breaker is on.
the wiring is very easy to hook up as black to black, white to white, and bare wire to ground.
i dont see how your husband could have done that wrong, but anything is possible.
recheck the power to the unit and just hope thats all thats wrong.
if you are sure power is good, then something in the unit has shorted out.
Jan 31, 2009 | Dishwashers
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
