Question about Pride Go-Go Ultra X 3-Wheel Travel Scooter
Electric motor heats up and stops after using for about 15 to 20 minutes, when it cools it runs for a short time
Unit has new batteries, the 15 amp circuit breaker has been replaced. When it gets hot the unit starts to sputter and stop working, no beep codes can be heard.
    Sergeant:
  • 313 Answers
First I would recommend releasing the brake and make sure the transaxial is free to turn. If not it could be the brake unit is either faulty or there may be dust/dirt/grit in the brake.
Another place to look is behind the wheels where I have found in the past, string had got rapped around the axial and cause the drive to stiffen up.
Posted on Apr 28, 2015
  • 49 Answers
If the motor is heating up more than usual, a couple of things
may be the source.
a) DC 24volt Motor itself has a shorted winding and using more current than normal. In that case the motor may need to be replaced. These DC motors have a commutated armature
that uses two carbon brushes. The carbon brushed do wear
down in time, so that could also be the source. The carbon
brushes are replaceable on pretty much all scooters and
can be obtained from MonsterScooter.
b) Controller issue where more current is being supplied to
the motor, but the motor itself determines how many amps
it draws from the batteries (ASSUMING FULL CHARGE HERE)
BASED ON THE BATTERY VOLTAGE, the lower the battery
voltage, the more current is required to move the transmission.
hi, now there is a real possibility the brake is not releasing fully , stressing the motor out ,,, have you removed a brush to inspect inside ? what about smell, ? smell burning ?
, Carefully remove the brake and test but keep it connected ?
The windings here could be the issue if the brake is not causing the problem
Areas to look at are :
Brake
Brushes
Motor Commutator
Motor winding , have one of the magnets within the motor come loose... noise would be a issue here..
Regards
Rob
www.gewizrepairs.co.uk
Apr 27, 2015 | Electric Health & Beauty
I have a RUUD central air conditioning system, model NBHC-18J20SFA. The cooling function is not working. The fan on the outdoor unit is not working. When switching to COOL, the compressor works for a few...
sounds like the outdoor fan motor and/or capacitor needs replaced. The compressor will run for a short time because the fan is not pulling the heat out of the system, it can cause damage to the compressor if the fan is not repaired, Ruud used a 3uf capacitor rating for the outdoor fan motor, if the motor has been changed make sure the proper capacitor is also changed for the new motor rating.
Jul 05, 2011 | Ruud UBHC Air Conditioner
My dryer shuts off after just a few minutes, but will restart after cooling down
if the motor stops running after it heats up most likely the overload is poping on the motor,when the motor cools down it will run again,you need to change out the motor
Aug 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
The dryer isn't getting hot. I know there's a
Hi
Thanks for using FixYa. If your dryer isn't working or isn't getting heated up, you'll need to check the following to be sure what exactly the issue is--
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Blows fuses or trips circuit breaker —GAS Models:
• If igniter is not glowing, check for 120 V at igniter.
• Igniter harness may be loose and shorted to base.
• Incorrect wiring or a wire shorted to ground.
If it runs for a few minutes and then stops, then check for the following:--
• Empty dryer.
• Check motor spins freely.
• Lint buildup around drive motor.
• Low voltage present.
• Blower impeller blocked in blower housing.
• Drive motor - start switch contacts stuck closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Hotpoint ultima cd80 condenser dryer has stopped heating can it be repaired/reset or is it a new unit and how much? Cheers
Hi
• Empty dryer.
Thanks
Rylee
Nov 10, 2009 | Hotpoint Dryers
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
Motor smokes
If an electric motor is smoking, most likely it is in the process of burning out the windings in the motor. This usually starts from using an extension cord that has too small a wire or a cord that is too long. when you do thid you are forcing the motor to pull more amps than it should to make up for the voltage loss in the cord.
The fuel for the electric motor is a term called watts. Watts equals volts times amps. If the voltage drops then more amps are needed to feed the motor enough watts. This caused the motor to over heat and this melts or breaks down the insulation on the windings. When this happens the motor starts to short out and once this happens then you can not save the motor.
Electric lawn equipment should be used with #14 or #12 (never use #16 or #18 gauge ) guage extension cords and should not be used with cords longer than 50 feet. Also you should not run the equipment more than 10 minutes with out a 30 minute rest.
Aug 27, 2009 | Toro Electric Ultra Blower/Vac 12 Amp
The a/c unit cooling fan shuts down shortly after unit kicks on.
If a fan motor quits working during a cycle it usually means that the thermal protector is turning it off. If you had an amp meter on it, you would notice that it is exceeding the listing on the nameplate, Nine times out of ten this is irreversable, the motor needs to be changed. Sometimes if there are oil ports on the motor, you can add a few drops of zoom spout oil and that does the trick. But usually the motor is already damaged. Good luck.
Jul 11, 2009 | Carrier 38CKC036 Air Conditioner
AC breaker trips after 10 minutes
Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric furnace , the same, but if its the outside unit, the fan could be going bad, locking up and the compressor still runs and pulls high ampsand tripps breaker or the compressor is just pulling too many amps due to plugged coils with dirt , grass or weeds blocking airflow.(koolbreezes74401@yahoo.com)
Jun 08, 2008 | Goodman CLQ36AR49 Air Conditioner
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Pride Go-Go Ultra X 3-Wheel Travel Scooter Logo
217 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
