Question about Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall Mounted Mini Split Inverter Heat Pump -
Timer blinking.outdoor unit does not functioning. what was the error?
Serial number of unit6836100153 / 2480800085
    Master:
  • 403 Answers
Looks like you said it, the outdoor unit is not working. Check for power to the outdoor unit or try cutting power to it, then after a minute restore power in attempt to reset it.
Posted on May 02, 2015
Fujitsu asta12lcc timer flashes 5 times
From the service manual:
Serial forward transfer error during the operation
When the outdoor unit does not receive the signal for 10 consecutive seconds during the operation > Outdoor unit stops.
[Diagnosis Point]
Check the indoor /outdoor cable connection (in order). If the cable wiring is not abnormal, measure the voltage of the outdoor unit terminals and diagnose the defective location.
(Refer to the after mentioned [Serial Signal Diagnosis] for the voltage measuring method and diagnosis method.)
Jan 17, 2017 | Fujitsu Heating & Cooling
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
ASTA09JEC Fujitsu model number operation light not on but time light (red/orange) flashing turns on then turns off automatically I have tried the reset button and turned the timer off on the remote
This is a serial signal error which means the outdoor unit is not talking to the indoor unit or vice versa. Most likely the outdoor board is stuffed but you need to count how many times the timer flashes to be absolutely sure which error it is. If you turn power off at the isolator for 5 mins then restart, this can sometimes clear an error caused by power supply fluctuations. If not, you will have to replace one of the boards. Indoor board allow around $200 - $250, outdoor board allow around $300 - $400.
May 09, 2015 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
Error code timer light blinks twice
Depending on the model, this usually means "Serial signal (reverse) error at start up" which means that the indoor unit is not receiving a response from the outdoor unit when it tries to "talk" to it. It can be several causes but In my experience, it is usually the outdoor controller board. Again, depending on the model, there can be several boards in the outdoor unit any or all of which could be causing the fault as well as a faulty fan motor or compressor. The bottom line is that you are going to need a tech to take a look at it to diagnose properly.
Apr 07, 2014 | Fujitsu Heating & Cooling
Repeating flash
Serial signal (reverse) error, at operation start up. Usually a faulty outdoor controller board but this one has about six PCB'S in the outdoor unit so your going to need a tech to look at it.
Jan 23, 2014 | Fujitsu Heating & Cooling
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Jul 30, 2013 | Fujitsu 24C1 Air Conditioner
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
I have a friedrich ductless split m# mw24cy3f .. call for cool only fan runs inside, call for heat nothing runs, outdoor temp at the moment is 38 degrees, error code light blinks on indoor unit......
not able to find the error codes for the unit number you gave but, here is a number you can call to get them. sorry not more help.
1-866-793-0323 spacer.gif Mon - Fri 9:00am to 6:00pm EST
Dec 20, 2010 | Friedrich Heating & Cooling
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Panasonic CU-E18JKK-1/CS-E18JKKW-1 Wall Mounted Mini Split Inverter Heat Pump - Logo
256 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
