Question about Dryers
Hawkins inframatic cuisinette heating element
Need instructions for Hawkins classic 2.0 litre pressure cooker
Here are the Hawkins pressure cooker manuals, plus a recipe booklet:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Dec 09, 2015 | Hawkins Classic Aluminum Pressure Cooker
My inframatic has stopped heating, what do i do/
Disconnect AC power at wall for safety.
If you can open up the coffee machine and find the heating element then you can use a simple multimeter on ohms scale and check the element for open.
If you are competent with electricity you can also use the multimeter on AC range and check for voltage going into element.
So.... If element is open then find a part number for this assembly and find a replacement.
I did this very same thing on my DeLonghi Coffee machine just last week. The Element was open circuit.
Trouble was it took 3 months to locate & order a replacement assembly (for a reasonable price) So $105 later I am now enjoying decent coffee again.
Good Luck
Nov 25, 2014 | Coffee Makers & Espresso Machines
Cal spa sp220 wont heat up. I got it to heat up once & it got suped hot then it stopped. How do I turn it back 0n ?
Look for a reset button on the heater. If you have a hawkins no fault it will be on the flat side where the power cord goes in. Most other heaters will have a red button either facing out at you or it will be under the black box.
Oct 07, 2013 | Pool & Spa
Hawkins inframatic after switching on the main fuse of the house trips
i am having a hawkins inframatic cuisinette since 1988 .it was working fine but due to aging of the cable/wire of the heating element, the coil got short . So please suggest me how can i get the spare coil to replace.
Jul 23, 2010 | Kitchen Appliances - Others
Shuts off
EE12 is an over heat condition. Clean the screen on the back of the heater and restart. Error code are explained on the lower left side panel.
Tom Hawkins
Bethel, Alaska
Feb 02, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Does not extinguish
If your fuel was yellow it was #2 home heating oil. Toyotomi Laser heater run well on #1. Since yours in giving you a EE10 message you are going to have to open the burner and clean it, the blower and the heat exchanger. The air holes are blocked on the burner and it takes too long to burn the fuel up, EE10.
This is a dirty job but not that difficult. Try toyotomiusa.com/ and use their dealer locator. You should find a dealer in South Dakota that will be able to get you some gaskets you might need.
Good luck,
Tom Hawkins
hawkins111@gci.net
Jan 27, 2009 | Rinnai Toyostove Direct Vent Heater:...
Dryers Logo
Top Dryers Experts
