Question about Kyocera Office Equipment & Supplies
Buying the Best Multifunction Heavy duty Printer
Nashuatec SP C830DN and Kyocera TASkalfa TA-3051Ci I want to buy the best among the Two printers stated but i want one which can scan A3 on ADF using Twain software One which can print to good high resolutions on graphics papers, Bond paper and with a good paper finisher Please give me your advice urgently
  • 186 Answers
After looking at specs I would say the Kyocera TASkalfa TA-3051Ci but I never used nor worked on one
Posted on Jul 06, 2017
  • 7 Answers
SOURCE: HP Officejet 6210 Printer; Paper Jam
Best Solution take off the small panel on the left side of the printer there you can see the white gears and one has a clear piece with black letters or dots on it with the panel removed look at the clear piece and try to start your printer if it does not rotate with the gear that is your problem. It is what tells the printer if the gears are moving or not. If that's the problem you have to take the printer almost all the way apart to be able to fix it.
Posted on Jan 26, 2008
SOURCE: which is best low cost per page inkjet printer
The new 8500 series OfficeJet Pros. The 940XL black cartridge gets about 2200 pages for $36 and the color ones get about 1700 for $25 (three colors).
Posted on Mar 30, 2009
SOURCE: I have problem printing A3 size paper in HP DJ1280
dear use hp 1220c driver instead of 1280
the problem will be sorted-out
Posted on May 05, 2009
  • 7993 Answers
SOURCE: how to print using ADF feeder?
You take the paper with face to print Up and the top of the paper towards the interior of the ADF. You can also put a stack of papers. When you press the copy/scan command from the machine console or the computer, the automatic document feeder starts.
Posted on Jan 06, 2010
Testimonial: "Thanks.. I understand now.. Is not like canon. Canon could change the feeder from ADF or bottom."
SOURCE: I have hp 1280 A3 Inkjet printer . When I give pri...
I have hp 1280 A3 Inkjet printer . When I give print it pick up paper and out the blank paper without printing . a4 printing is ok. But A3 Is majour problem
Posted on Jun 01, 2010
I have kyocera taskalfa 221 error code 6000 what can i do
I am afraid that your heater lamp is broken.
You will need to replace your fixing unit.
Best regards,
Nov 04, 2016 | Kyocera Office Equipment & Supplies
Paper printing hot and curling on kyocera taskalfa do i remedy that problem.
Paper curling is usually caused by one of two things:
1. old damp or moist paper that has too much humidity in it. Easy test for this is to open a brand new ream of paper and try fresh paper.
2. The fuser temperature is too hot for the paper you are printing on. If you can set paper type on your printer, make sure it matches the actual paper, for instance, plain paper, heavy paper.
Feb 19, 2015 | Kyocera Office Equipment & Supplies
My kyocera taskalfa 180 do not print. operator can not find out any problem. he has checked major 3 unit.
All new copier/printer has safety pacageging SCREW /TAPES to prevent damage in traveling/shipping w/ it your Kyocera taskalfa 180 won't print, look for it and remove it all usually it is color orange 1 of them located at Optics unit .
Nov 21, 2014 | Kyocera Mita TASKalfa 180 Black Toner...
Code 2103
Developer motor MCY error
After developer motor MCY is
driven, the ready signal does
not turn to L within 5 s.
stabilized, the ready signal is
at the H level for 5 s continuously
Aug 08, 2014 | Kyocera Office Equipment & Supplies
Sc552-03 on my ricoh Aficio sp c830DN please what is the remedy
Jun 05, 2013 | Office Equipment & Supplies
How to access service mode on sp830dn
Press the mode /clear (yellow)key press 107 press more than 4 seconds the stop/clear(red) key and in display SP mode.
Feb 21, 2013 | Ricoh Aficio SP C830DN - Printer - color -...
Kyocera printing black pages
Quite sure this is the main charger. Replacing it is best fix, but you must have heard this already.
Jan 22, 2013 | Copystar Kyocera Taskalfa 420i...
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
How is the performance of this printer ? is it worth to buy ?
hi there! with regards to this printer if its worth buying, check this link.. and see for yourself.. for me its not.. there is a list of comparison and see for your self which is best fit for you .. here is the link ..;rnav
I hope this will help.. happy buying..
Aug 10, 2009 | Brother DCP-7030 Digital All-in-One Laser...
117 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
