Question about Dryers
I am having a hawkins inframatic cuisinette since 1988 .it was working fine but due to aging of the cable/wire of the heating element, the coil got short .
Heating coil assembly
Jimster
  • 240 Answers
SOURCE: amana dryer heating element
Sounds like it is your element. If you got no continuity, that would be it for sure. Let me know if you need any other assistance.
Posted on Feb 13, 2008
MNTECH
  • 1543 Answers
SOURCE: baking element
oh bleep, right? well, if you're lucky this will get you going again. 1. disconnect power to range. 2. remove back metal cover just above range power cord (usually 5 quarter inch hex screws) 3. look for burnt off wire leading to/from bake element. If yes, 4. strip ends of broken wire and splice with ceramic wire nut if no 4. bad news. replace ERC (electronic range control) you fried something on the board. It's got the clock display and all the electronics behind it.
Posted on Aug 29, 2008
barkencoa
  • 3463 Answers
SOURCE: wirlpool dryer heating poorly
Make sure you have got it set to full heat and not half heat, you may have a faulty heat selector switch.
Posted on Dec 10, 2008
SOURCE: no heat
The solution provided may have helped if my neighbor had not disposed of the dryer before I could try the solution.
Thanks for the input.
Posted on Mar 24, 2009
  • 85 Answers
SOURCE: coil element on kitchen aid model ker1201 slow to
some of the coiled eyes have two coils(elements). one of the coils can burn into at any point around the element rendering it useless while the other can still work. when you lift the glass top you will see the elements are shaped like springs. the elements metal is very britlle.it is you have to replace the entire eye to fix it. the coil most likely had a very gap in the break and acted like a short making and breaking connection until the gap was too wide then nothing. easy fix. just replace the entire eye (power UNPLUGGED!!!) match the old wires with the new part as you take the old part off. I mark them even with a sharpie. it has 3 to 5 wires on that plug into the eye unit. estimated cost for the part online is about 40 to 65 bucks.
Posted on Jun 21, 2009
My inframatic has stopped heating, what do i do/
Disconnect AC power at wall for safety.
If you can open up the coffee machine and find the heating element then you can use a simple multimeter on ohms scale and check the element for open.
If you are competent with electricity you can also use the multimeter on AC range and check for voltage going into element.
So.... If element is open then find a part number for this assembly and find a replacement.
I did this very same thing on my DeLonghi Coffee machine just last week. The Element was open circuit.
Trouble was it took 3 months to locate & order a replacement assembly (for a reasonable price) So $105 later I am now enjoying decent coffee again.
Good Luck
Nov 25, 2014 | Coffee Makers & Espresso Machines
In wet and damp weather my 1988 Golf GT runs real rough and eventually stalls, but runs fine in dry conditions. What's going on?
sounds like its time for tune up wires and rotor cap and such..with age they break down and moisture is shorting some of this out..to test this using a spray bottle spray these wire down and listen for a snapping sound from the coil..this is proof of the water getting the old wiers wet..(condensate moisture)
Feb 15, 2013 | 1988 Volkswagen Golf
Lower heating element of oven does not heat at all. Think we saw it sparking before it quit working, not sure why it would do that. Oven is very clean, nothing on walls or on element. Was recently cleaned...
The element sparking and short circuiting has nothing to do with the cleanliness of the oven. An element will break down internally and short circuit due to it's age or hours of service. Have a look at the element to see if there are any holes/blow marks on it. If there are it requires replacement. Sometimes the element will look fine but will still be faulty.
Feb 26, 2011 | Thermador Ovens
HEATER NOT WORKING PROPERLY (SOME HEAT BUT NOT HOT) COMPRESSOR NOT RUNNING WHEN IN HEAT MODE. A/C WORKS FINE.
No adequate heat due to wrong setting temp or your RV (Reversible valve) not working properly.
Set temp +5 than your room temp and mode in " Heat". And check click sound in reversible valve and also warm in sunction line.
If it's with heating element check power goes heater coil. If not check wiring.
Dec 27, 2010 | Heating & Cooling
How likely is it that the coil/element fails?
Hello
The heating element in electric dryers usually don't go bad, they might work for 10-15 yrs. When the dryer stops heating its usually due to the Thermal fuse that goes bad and cannot be reset. The age of heating elements also depends on the usage/loads/ frequency of dryer. Please get back to me if you have any other questions.
Kevin
Nov 18, 2010 | GE DBXR463EBWW Electric Dryer
Everything seems to work fine, but dryer does not heat
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Oct 01, 2010 | Kenmore 62062 Electric Dryer
Hawkins inframatic after switching on the main fuse of the house trips
i am having a hawkins inframatic cuisinette since 1988 .it was working fine but due to aging of the cable/wire of the heating element, the coil got short . So please suggest me how can i get the spare coil to replace.
Jul 23, 2010 | Kitchen Appliances - Others
Kenmore electric dryer 8662100 drum turns, no heat
you have probably lost one leg of your power supply feed 120volts+120volts=240volts,your motor will operate on 120volts, but the element won't,also if you have 240volts the neutral wire to the element can burn off w/heat and age
Aug 18, 2009 | Kenmore 84152 Electric Dryer
No heat from dryer
It is most likely the heating element. If you would like to access the element, just take the 3 screws out of the bottom of the kick plate below the door and you will see the element in a canister. There should be a screw on the side of the canister that holds the element in. Remove this screw and pull wires off the element, after you have noted where the wires to the element are properly placed. Then proceed to pull the element straight out of the canister. Inspect the wire coils for breakage, If you find a broken coil wire, replace the element. If you do not find a broken coil wire then proceed to checking the high limit cut off thermals located on the side of the canister for continuity. If you find one of the thermals not to have continuity, replace both thermals. They come in a package together as one kit. Hope this helps. Dave
Mar 30, 2009 | Whirlpool LER5636P Electric Dryer
Oven does not heat up beyond 240 degrees, which takes a long time
You have either a burned our lower element or a wire has burned off at the terminal for that element. The good news is that the lower element is cheaper.
Jan 28, 2009 | Kenmore 47783 Electric Single Oven
Dryers Logo
62 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
