Question about Tablets & eReaders
My a31 quad core android box model E05 won't go past the boot screen with the android icon on, it just goes blank. It's worked fine up to now.Firmware maybe?Any help would be appreciated Thanks,Chris
  • 142 Answers
SOURCE: Pin no. set in error on this tablet now we can't access the tablet at all because we ca't get past the pin no. Please help or advise how to restore to factor settings.
Do you mean that the PIN of the SIM card is locked?
The PIN is needed to access the SIM card.
If you remove the SIM card the tablet will not ask for a PIN.
You do not need to change anything in the tablet.
(If you would insert your SIM card in a phone, the same would happen when you launch the phone.)
I hope this helps.
Posted on May 11, 2014
Testimonial: "The tablet does not have a sim card. Just a basic tablet with a number password instead of a pattern. many thanks"
  • 186 Answers
SOURCE: I have a brand new out the box Brix Phablet n
Take it back where you bought it and ask for help with it.
Posted on Dec 08, 2014
Testimonial: "Jim Evans has been great with me about my issue with a tablet i just bought! Much appreciated!!"
  • 742 Answers
SOURCE: I have an AllWinner Q102 Android 4.4.2 Tablet 10.1" A31S Quad Core . I had to get a different charger for it because the one it came with was from Europe and their wall plugins are different than in C
Your power cord may not be putting out enough current. Check and make sure it is the right adaptor for your tablet
Posted on Jan 09, 2015
ving911
  • 6 Answers
SOURCE: I brought a ematic 7" Quad-Core tablet with Android 4.2 Jelly Bean. When I turned the tablet on and it go thru it cycle it show on the screen unfortunately, rstech_teni has stopped.
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Posted on Jan 26, 2015
easybill99
  • 996 Answers
SOURCE: Is it possible to retrieve my Android 4.2 program if I have lost it?
hard reset with recovery options
Posted on Jan 31, 2015
Proscan tablet stuck on android screen
The Issue
The problem usually presents itself like this: you boot up your tablet and the tablet reaches the Android logo and hangs there and never moves. If you attempt to restart or reset the tablet through the Android recovery mode that too does not help and the tablet is basically useless as it will not start-up.
Why is my tablet stuck on the Android Screen?
The issue is caused by a corrupted or none functioning Android operating system and the only way to get your device back to a functional state is to reflash the original firmware or a compatible version
Devices will no work
This will work on any Android tablet with the issue, however it works best with tablets that look like the Alldaymall A13 MID or the Irulu AK304 which we have tested this on and others, it's a simple matter of finding the correct fir
What will I need to fix this Issue?
You will need:
1. A MicroSD Card.
2. A means of connecting the MicroSD card to the PC/a MicroSD Card to USB converter
3. Your Tablets Firmware:
Alldaymall A13 MID Firmware:
Irulu AK304 Firmware:
4. Download thoenix Card
How to Fix your tablet that is Stuck on the Android Logo?
1. You will need to get the relevant items from the list above that includes the MicroSD card, the SDCard adapter,phoenix card tool and your appropriate firmware for your model tablet. show you what to do step by step
Sep 30, 2016 | Tablets & eReaders
Won't boot past tv face
Won't boot past tv face - Fixya
www.fixya.com/support/t26041897-boot_past_tv_face
34 mins ago - Won't boot past tv face - Kurio 7S Tablet question. ... How do I show a video from face book it just boots me off. Dec 20, 2014 ' Apple iPad 2.
My kurio 7 tablet is stuck in the kurio loading page. What can ...
www.askmefast.com > Computers & Internet > Google > Tablet
Kurio 7 tablet how to fix when the smiley face screen stays on the screen .... Kurio 4s wont pass start up ... Kurio 7 won t go pass the smiley box ..... My kurio 7 has been dead for awhile and is stuck on the screen with the little tv what do i do?
[PDF]INSTRUCTION MANUAL - Kurio
www.kurioworld.com/k/us/parents/pdf/Kurio7_Manual_US.pdf
The Ultimate Android™ Tablet for Families™ .... Connect Kurio to TV screen. .....Note: The reactivity of the touch screen can vary from one person to another, which is linked to the nature ... To exit the Android interface and go back to Kurio interface, press . .... When the icon is like this , the user won't be able to delete or add.
Getting started - Kurio 7 - Kurio Tablets
www.kurioworld.com/k/us/parents/support/7/gettingstarted
Jan 06, 2016 | Kurio 7S Tablet
Instruction manual for Tagital® T7X 7 Quad Core Android 4.4 KitKat Tablet PC
Tagital® T7X 7" Quad Core Android 4.4 KitKat Tablet PC ...
www.amazon.com/Tagital®-T7X.../B00RLEKHVA
Amazon.com, Inc.
Rating: 3.6 - ‎132 reviews
Amazon.com : Tagital® T7X 7" Quad Core Android 4.4 KitKat Tablet PC, Bluetooth, Dual Camera, Play Store Pre-installed, 2015 Newest ... 1x User's Manual
Tagital® T7X 7" Quad Core Android 4.4 KitKat ... - YouTube
? 1:44
https://www.youtube.com/watch?v=bux7EbSlAKM
Aug 12, 2015 - Uploaded by Ritz Flash
4 GB Storage (Supports Micro SD card extension) Package: 1xTagital Android 4.4 Qual Core 7" Tablet 1x ...
Tagital® T7X 7? Quad Core Android 4.4 KitKat Ta
Jan 05, 2016 | Tablets & eReaders
Irulu Expro tablet. Where is the Bluetooth setting?
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 ...
https://www.irulu.com/tablet/p-irulu-expro-x1plus-10.1-inch-quad-core-t...
iRULU eXpro X1Plus 10.1 inch quad core tablet Android 5.1 Lollipop support Wifi OTG ... Bluetooth: 4.0 ... iRulu Google Android Capacitive Tablet PC(1) ... 1 Comments 0 or 0 people found the following review helpful .... Connect With Us.
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core
https://www.irulu.com/tablet/p-irulu-expro-x2plus-series-android-4.4-hig...
iRULU eXpro X2Plus series android 4.4 high-speed Octa Core Tablet 16GB ROM 10 points Capacitive IPS touch screen Bluetooth 4.2. $89.99 $179.99.
Irulu Tablet - Android Forums at AndroidCentral.com
Dec 26, 2015 | Tablets & eReaders
Need a user manual for a andriod dx758 pro tablet quad core 7in screen 8gb
Amazon.com : iROLA DX758 Tablet PC- 7", Quad Core ...
www.amazon.com/DX758...Android.../B00U1Q1156
Amazon.com, Inc.... OTG cable, screen protector, stylus pen, carrying pouch, user manual. Industry ... Kocaso DX758 8GB 7" Kids' Tablet with Android OS, Protective Case, Stylus, ...
Dec 20, 2015 | Tablets & eReaders
Hi my MID ANDROID TABLET PC4.1 will boot on power but I cannot get any play screen what can I do
Usually you have to reset the unit. Try turning off the power then press the power button for about fifteen seconds then let it go and see if this solves the problems.
Sep 20, 2014 | Ramos Ant Team W21 7 Android 4.1 Jelly...
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
Tablets & eReaders Logo
35 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
