Question about Dryers
The dryer doesn't get warm,it's new purchased 4/24/15
    Top Expert:
  • Dryers Master
  • 10,875 Answers
TAKE IT BACK!! you shouldnt even have any doubts to ask how to fix it,you paid for a working machine it is warranted for 30 days from the store or 1 year manufacturer
Posted on Apr 28, 2015
My Oster wafflemaker doesn't get hot! The lights are on but only gets warm
One or more of the heating elements are not activating. If you take it apart, perhaps you can do a continuity test on each element to see which is bad. I don't believe they sell element replacements so your only choice would be a new purchase or warranty.
Jan 29, 2013 | Kitchen Appliances - Others
My dryer doesn'n warm up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Kenmore Dryers
My kenmore dryer doesn't warm up
First check the lint screen. If it's caked up, clean it. Secondly, check the exhaust duct for any lint build up. The build up usually occurs where the duct exits the house. If it's blocked, clear the exhaust vent.
Gas dryer, runs fine for maybe 10 minutes than the heat goes off and doesn't come back on...change the thermal kit and no fix
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
This is what the coils looks like
Aug 25, 2011 | Dryers
The drum turns. It heats up. But only small loads of cotton get dry! We have changed the vent tube. Vacuumed the vent the lint catcher area and around the drum to remove lint and hair. Still not...
A very typical problem with GAS dryers is the soloniod coils that open the gas valve . When the coils are cool they operate just fine,but once the dryer gets warm from running the coils dont open the gas valve wwhen they are warm. If that is what your experiencing,the dryer heats when its cool but doesn't heat when it's been running for a while,the coils on the gas valve will need to be replaced.
GENE
Aug 16, 2011 | Roper RGX4634KQ Gas Dryer
Ive just installed a new door kit onto my fisher and paykel de45f56a dryer. It has never had a door as it was cracked when purchased so the dryer has never been started. I have now fitted the door however...
yes, double check the switch first. it sounds like the motor is not even moving, since the dryer was never used before sometimes there is a "tab" or locking mechanism to keep the tumbler form moving during shipping.
Mar 27, 2017 | Dryers
Hotpoint tcm 570 warms up but doesn't spin
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 14, 2011 | Dryers
Dryer not putting out warm to hot air. What is the issue?
Hope this info helps, ps don't forget to give me a rating thanks!!
For an electric dryer that runs but doesn’t heat, follow this repair roadmap:
Flip the circuit breaker off and then back on. Electric dryers run on a two-pole, 240v breaker. A common problem is for one of the legs to break which cuts the 240v that the elements need to heat up but it still supplies the 120v for the motor. The result is that the dryer runs but doesn’t heat.
If the breaker checks out, then it’s time to do some surgery. Unplug the dryer and open it up.
. Use your ohm meter to test the thermostats. All should show continuity.
Measure the resistance of the heating element with your ohm meter. Normal readings are in the neighborhood of 30 ohms.
In rare cases, the centrifugal switch in the motor can fail which breaks the power circuit for the heating elements. If this is the case, then the entire motor must be replaced since the centrifugal switch is built into the motor.
May 07, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
55 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
