Question about Science & Laboratory
MTN Gearsmith Model yx-18LM We need a new submersible heat element.
3 Suggested Answers
  • 170 Answers
SOURCE: We bought a new Mtn gearsmith electric meat
You posted your Appliance problem in the Cars and Trucks area.
Oops.
Posted on Jul 05, 2014
124joe
  • 3 Answers
SOURCE: I have an MTN gearsmith 20 liter autoclave. The autoclave tripped the reset button for the GFCI. It will not turn on. Any advice is welcome
it seems to be in the middle of a cycle and needs to finish
but shorting out.so unplug it and inspect the power cord at both ends
you may need to remove a pannel to get to where it gives power
look for any spot that over heated or arcing spots
also the back side of the control pannel
if you find the bad wire you will know right away
hope this helps joe.
Posted on Nov 15, 2016
Tip
How to Replace the Dishwasher Heating Element
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
on Apr 19, 2010 | Dishwashers
Nov 14, 2016 | Washing Machines
Lack of water
Is it filled with water? If yes, then the liquid level sensor has failed in the unit. This will happen normally, but does happen frequently if you have growth in the water reservoir. Call for service. Follow instruction in the manual about flushing the reservoir.
Feb 16, 2014 | MTN Gearsmith New 1500w Commercial...
How do I replace cord for MTN Kitchenware model YX-280B 18L portable pressure steam sterilizer?
Good question! I have the same one and the cord just let out a lightening bolt and loud pop and blew away the outer covering. I cant find one either. Did you ever find one????
Oct 26, 2013 | Baby Care
Science & Laboratory Logo
663 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
