Question about SanDisk Sansa e140 MP3 Player
Detected by the pc but no changes are made
So my sanse e140 can be detected by the computer. i can delete and add files if the unit is connected to the computer and the changes are recognized. once i remove the connection from the pc and the unit and i turn on the unit, the changes (songs deleted and songs added) are not recognized.
  • toonpham1 Aug 14, 2008
    i have a problem the problem is that wen i turn on the sansa e140 it just goes right to the same thing OVER AND OVER again its says internal thats all
    searching
    for new music
  • 684 Answers
On the Mp3 player u will see a small slide switch which says Hold/Unhold try to slide that switch to the opposite direction
Posted on Aug 03, 2008
Dont know how to add files
When you connect the MP3 player to your computer with the supplied USB cable then computer detects the player as an external storage device or a Removable disk, you can then view the folder on your MP3 player. Open the music folder and create a new folder on the player exactly the same way you create a folder on your computer's hard drive. To organise your music, make a folder name with the name of the music album and place the album's MP3 files in this folder, then copy the mp3 files from the computer into this folder.
You will then be able to select the music you want to play by the music album folder. To delete a file from your MP3 player, connect the supplied USB cable to your player and then plug it into the USB port of your computer.
The computer will detect your player then click on this device to view the files, you can then click on the music file to highlight the file and then press the Del key to delete the file off your MP3 player.
Jan 08, 2013 | Audio Players & Recorders
How do i take some memory off the sandisk sanse mp3 player?
1. Connect the USB cable to your Sansa MP3 player, then hook the other end to a free USB port on your computer. 2. Give the computer time to recognize the Sansa MP3 player. Once it has, double-click on the MP3 player?s icon to view the music files stored to memory. 3. Scroll through the list of audio files until you find the ones that you wish to delete from the Sansa MP3 player. 4. Click on single items or click and lasso multiple files. 5. Right-click on the highlighted files to pull down an action list and from there select Delete. The computer will ask if you really want to throw the file away. Select OK. 6. Exit from the window, then disconnect the USB cable from the Sansa MP3 player. The player will automatically turn off. The memory will update the first time you turn the player on after deleting songs.
Sep 30, 2009 | SanDisk Sansa m240 MP3 Player
I CAN'T ADD OR DELETE FILES. IT SAY NO FILES
Hi..
In that case you need to format your unit, because it is infected by viruses some of your files are corrupted.
Plug your unit in your computer, once your unit has been detected open my computer, right click your removable unit and format.
Thank you and good luck!
Regards
PCmania
Sep 23, 2009 | SanDisk Sansa m230 MP3 Player
I have aquired an e140 1GB MP3 and need a manual.
http://www.sandisk.com/assets/File/pdf/guides/sansa-e100-userguide.pdf
I believe this should be the manual that your looking for. You may also want to try hooking the MP3 player up to your computer via the usb cable. After doing so, if nothing automatically comes up, you should be able to open the players drive via the my computer option. A lot of times a copy of the manual and the operating software can be found here.
Jul 27, 2009 | SanDisk Audio Players & Recorders
Hey can you tell me how to fi this problem my san disk e140 is telling me not enough memory cnnect to the pc delete 4m of songs for sansa system.i have tried everything it told me and it still do not work...
to solve the problem do the following things:
- download the firmware (http://www.sandisk.com/Retail/Default.aspx?CatID=1295)
- run firmware - SW
- FirmwareDownloader shows "Detecting"
- put oft the battery of the e140
- hold down the Power Button
- Connect the e140 to the PC
- FirmwareDownloader shows "Recovery mode ready"
- press start-Button
--> e140 works
Sep 28, 2008 | SanDisk Sansa e140 MP3 Player
Sansa e140 error
There is a Problem with the flash memory on the Mp3 player I would request u too replace it
Aug 03, 2008 | SanDisk Sansa e140 MP3 Player
Can not access device neither directly nor via PC
I have the same frigging problem with mine. What's the solution?
Mar 19, 2008 | SanDisk Sansa e140 MP3 Player
No change is recognized in the playlist
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | SanDisk Sansa e140 MP3 Player
Don't know how to delete files
1. Open the file browser on your computer and navigate through the folders to the drive assigned to your Sansa MP3 Player. 2. Select the music files that you would like to delete by clicking once on the file, if you want to delete more than one file hold your control(ctrl) key down as you click each file. When you have clicked on all the files you want deleted release holding down the control key. Then push the delete key. The files will be deleted. You also can use Rhapsody and other software to save or delete files directly to your player.
Jul 14, 2007 | SanDisk Sansa e140 MP3 Player
Not detecting sansae140
Pls call the customer service Ph# 800-426-6027 they will help u out with it
May 30, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
