Kitchenaide no. 8537797 touch pad not lighting up at all. Also won't completely drain.
    Habit-Forming:
    New Friend:
  • 28 Answers
Check loose connection cable under touch pad. you first open it and see connection.
Posted on Apr 28, 2015
  • Anonymous Apr 30, 2015
    No loose connections. Could it be the thermistor? Voltage across power in is 92v.
  • edris
    edris May 06, 2015
    ok. yes may be. check it.
Milk was spilled on the touchpad of my laptop the cursor moves but it won't click
You need to replace the touch pad or you can connect an USB mouse to your laptop and not use the touch pad.
Mar 21, 2013 | Dell Inspiron Computers & Internet
Brakelights won't go off on my 1998 Escort
Your brake lights stay on due to a small rubber pad about the side of a nickel, which is supposed to be stuck in a small hole about 6 inches above your brake pedal, way up where you have to stick your head under the dashboard to see it, with a flash light. if you look up there & you can see that it is missing, you need a new one from the dealer. if the rubber pad is intact, then the switch that it touches (plunger-type switch) is bad. That is the brake light activation switch. Usually it's the rubber plug that has disintegrated.
Aug 29, 2012 | 1998 Ford Escort
Control lock on duet washer GHW9250ML1 is flashing, nothing working even after unplugging. When replugged, light starts to flash again and nothing else.
Here's what the Duet tech sheet says to do:
1. Press PAUSE/CANCEL button on the touch-pad twice.
2. Drain the unit, then check that the Drain hose and Drain Pump
Filter is clear of foreign objects.
3. Check/ Replace Touch-pad/LED assembly.
4. Check harness connections.
5. Check the CCU.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Touch pad sony viao vpceb3j1e not working
Hey there. Often times this is a problem caused by accidentally turning it off. Look for a button on your keyboard or near the touch pad to turn the touch pad on/off. If you're using windows 7 and possible below, you won't need drivers to get the touch pad to work normally.
Jul 26, 2011 | Computers & Internet
VIK ROSE 45010050 Stitch size button will go up but not down in size...
Possibly the touch pad is bad. Are they any other buttons that don't work? Usually when the touch pad is bad other buttons won't work either. If only the stitch length won't work then the step motor for the feed is bad or you have a bad board.
Apr 20, 2011 | Husqvarna Rose
No lights on, didnt complete the drain cycle, stopped working now
There is a thermal fuse located in the control panel inside the door. It could be blown, but if so what caused it. they come with a retrofit pigtail to prevent loose connectins on the fuse. You may have a short somewhere in the dryer, and just blow the fuse again. Could be bad motor,fill valve, or heater, or even the control board. I'd try one fuse first.
Jul 26, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAide washer keeps agitating in the rinse cycle-will not mo
It sounds like there is a dead spot in the timer. The timer is the control device behind the large knob on the right. The timer part number for you machine is 3955761 and runs about $150.00 for the part.
Apr 20, 2010 | KitchenAid KAWS850LE Top Load Washer
Control locked light is on and washer won't turn on. Can press "Control On" and Cancel/Pause buttons at the same time to get the power on but won't start.
Looking at the manual of my Whirlpool front loader gives me the following advice...
CONTROL WON’T ACCEPT SELECTIONS
2. Drain the unit, then check that the drain hose and drain
pump filter are clear of foreign objects.
3. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
4. Unplug washer or disconnect power.
5. Check harness connections.
6. Plug in washer or reconnect power.
7. Verify CCU operation by running a Diagnostic test or any
cycle
BTW: The full manual is at http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208182208.pdf
Mar 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I no longer have the scroll function on my touch pad for my Toshiba Satellite Laptop
Download the touch pad driver from the manufacturer's website.
Perform a complete power drain
Disable the mouse device from device manager and enable it.
This will work
Aug 12, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Computers & Internet Logo
David Payne
David Payne
