Question about HP Office Equipment & Supplies
Hp laserjet 9500 control panel failure after removing rhe formatter.
  • HP Master
  • 1,915 Answers
Control panel will not light with the formatter removed, it is controlled by the formatter. The only thing you can do with the formatter removed is an engine test.
Posted on Apr 28, 2015
SOURCE: HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Posted on Jul 07, 2008
SOURCE: HP laser Jet 2420
cannot print to the printer server
Posted on Jul 08, 2008
copiersplusw
  • 136 Answers
SOURCE: HP 4250 laserjet will not go through the start up sequence.
Well first do what joe said about checking the Plug on the Display, <Here's another solution did you also check the cables( Power Cables going to the format bd ? Sometimes you can bent those pins easily, I have seen it and ok I done it once on HP 4 plus when i first started out as a tech ? Check that ? May I asked What was the reason for replacing the Formatter board in the first Place ? were you getting an error ?
Posted on May 01, 2009
seeker5211
  • 1089 Answers
SOURCE: hp color laserjet 9500 error
Fuser fan is shot. Has to be replaced.
Rear, right side, the lower fan
Posted on Dec 28, 2010
Prefab
  • 152 Answers
SOURCE: problema con impresor hp laserjet
Hello, this error related to the additional memory installed into the printer. It could be just the memory or the Formatter board itself. The memory can can be removed quite simply.
1) Turn the power off to the printer.
2) Slide the right side cover off, moving it towards the back.
3) Remove the memory DIMM from the formatter board.
4) Turn the power to the printer back on.
Does the printer come "READY"? If yes, then the memory is bad, If NO then the formatter is bad and will need to be replaced.
A good source for part www.partsnow.com
Posted on Jan 15, 2011
Hp 4250 error code 55.4
error code 55.4 on HP Laserjet 4250:-The dc controller is not communicating with
the formatter. The problem could be caused
by a timing error or an intermittent
connection
Repair:-
switch off the unit - disconnect power cord
unsrew the two screws holding the formatter in place
( silver plate to rear right)
remove the plastic side panel by sliding
remove the formatter ( silver box you just unscrewed) by sliding toward the rear.
reinstall the Formatter
and re-test
more often than not just reconnecting the controller is enough to clear the problem. theres a good chance it has moved out of position as time has gone by.
Jan 22, 2013 | HP LaserJet 4250n Printer
My hp laserjet m1522 powers on then hangs
Check voltage between 1 & 12 connector J32 on formatter should be 5V, if no replace DC controller(engine controller PCA),P.No RM 4932-000cn(120V), RM4936-000cn(220V).If voltage is good replace Formatter..P.No.CC396-60001
Oct 18, 2011 | HP LaserJet M1522nf Multifunction Printer...
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
Aug 30, 2011 | HP LaserJet M5035 MFP Printer
Hp p4014n, erro 55,00,00 controlador, cc
55.XX.YY DC CONTROLLER ERROR
A temporary printing error occurred.
1. Turn the product off and then on.
2. Remove any third-party memory or USB
device, and then turn the product off and
then on.
3. Remove and then reinstall the formatter. (the formatter is the logic board)
4. If the error persists, remove the
formatter and perform an engine test***. If the engine test page fails to print,replace the DC controller. If the engine test page prints, replace the formatter.
***engine test
To verify that the product engine (all product components except the formatter, formatter DIMMs,
EIO products, and the stacker or stapler/stacker) is functioning, print an engine-test page. Use a small, non-metallic, pointed object to depress the test-page switch, which is accessible through a slot in the right-side cover.
The test page should have a series of horizontal lines.
A damaged formatter might interfere with the engine test. If the engine-test page does not print,
try removing the formatter and performing the engine test again. If the engine test is then successful, the problem is almost certainly with the formatter, the control panel, or the cable that connects them.
Jun 01, 2011 | HP LaserJet P4014n Printer
Problema con impresor hp laserjet p3005, da mensaje "MEM TEST FAILURE REPLACE DIMM 0", y cuesta que en el panel de control aparezca preparado.
Jan 13, 2011 | HP LaserJet P3005n Printer
My M2727nf is not not initilizing and is out of warranty I sent it to an othorized HP service center and they told me that I need to change the formater. Where can I buy this formater and find the guide to...
1. Remove the left cover.
2. Disconnect five connectors (callout 1; GND wire lug, J36, J2, J32, J34) and five FFCs (callout 2;
J4, J27, J28, J31, J26).
Remove the formatter (1 of 5)1
132 Chapter 5 Removal and replacement ENWW
3. Remove six screws (callout 3), and then separate the formatter from the product.
Remove the formatter (2 of 5)
CAUTION: Make sure that you install the protective sheet behind the formatter when you reinstall
it. Failure to install the protective sheet might cause a short circuit and damage the formatter.
4. For products that use an Asian character control panel only
: use a pair of needle nose pliers
to release the Asian-character control-panel-display PCA spacer from the formatter.
5. For products that use an Asian character control panel only: remove the Asian-character
control-panel-display PCA from the formatter. Install the PCA on the replacement formatter
(connector H3).
Here's where you can get your formatter... Click Here!!
Hope this heps and if so Please mark this a FixYa!!
Jul 17, 2010 | HP Laserjet M2727nf Multifunction Printer
Replace dim 0
The Dim is on panel that has the jetdirect card. Remove the Jetdirect panel/network card, remove the faulty DIM and replace with good one and replace the jetdirect panel.
Jun 15, 2010 | HP LaserJet P3005n Printer
Hp laserjet 8150 black blocks lcd display
If the printer isn't intializing then you may have a formatter issue. Try reseating the the formatter in the back of the printer. There is two thumb screws that hold it in place. If the printer is booting up and you can still print to it but you just can't read the control panel then the problem is with the control panel.
May 17, 2010 | HP LaserJet 8150n Printer
HP laser Jet 2420
Jul 04, 2008 | HP LaserJet 2420 Printer
44 people viewed this question
Seeker5211
Seeker5211
