Question about Kenmore Double 27" Electric Built-in Wall Oven W Manual
How do I unplug built in oven kenmore 911? - Kenmore Double 27" Electric Built-in Wall Oven W Manual
    Top Expert:
  • Kenmore Master
  • 51,204 Answers
There may not be a plug in for this unit as most ovens are hard wired and will require an electrician to disconnect safely
Posted on Apr 28, 2015
Bake element not working
You will need to replace the oven control ERC
Jan 25, 2014 | Kenmore Ovens
Tip
SEARS / KENMORE Range/Stove/Oven Manufacturers
SEARS/KENMORE
Sears is a department store. They do not build their own appliances. They contract with many different manufacturers to build all of their appliances. This chart will help you determine who actually built your appliance, then you can choose the manufacturer from the charts on this page.
The first 3 digits of the model number determine who built your Sears / Kenmore Unit. This can be helpful if looking for repair or replacement parts.
Your model is manufactured by the following if your units first digits starts with:
Amana 596
Caloric 174 / 960
D & M 587
Fedders 484
GE 362 / 363
Gibson 253
Jenn Air 829
Kelvinator 417 / 628 / 662
Litton 747
Maytag 925
Roper 103 / 155 / 647 / 835 / 911
Speed Queen 651
Tappan 79
Toshiba 562
WCI 790
Whirlpool 106 / 110 / 198 / 562 / 665
on Jun 10, 2011 | Ovens
F3 code on Kenmore Oven Model 911 4558810
The F3 error code indicates that the EOC (Electronic Oven Control board) senses a problem with the oven temperature sensor. You could have a defective sensor, a failed EOC or a bad wiring connection between these 2 components.
Normally, a technician is needed to diagnose and repair this type of failure. The technician would unplug the range and access the EOC in the console. He would pull the 15-pin plug from the EOC and measure the resistance between pins 12 and 13 of the plug. This would check the temperature sensor and connecting wiring. The tech should measure about 11000 ohms at room temperature (75 degrees Fahrenheit).
If this reading is good, the EOC would be the failed component and would need to be replaced.
If the resistance reading of the sensor circuit is bad, the reading would be taken directly from the leads on the temperature sensor. If the resistance reading taken directly off the sensor is bad, then the temperature sensor has failed and would need to be replaced. Otherwise, the wire harness is the failed component.
If you have a volt/ohm meter and the technical expertise to safely access and test internal components of your range as described above, you may be able to diagnose and repair the range yourself.
Feb 18, 2013 | Kenmore Ovens
F3 error code on Kenmore 911-45569690
Yep F3 I dont even have to look that up fault with oven tempreture sensor. If you perform an ohms test on it at room tempreture should read between 1000-1100 ohms if less then replace. Thanks again
Rick
Nov 24, 2011 | Ovens
Audible alarm sounded--"F2 "appeared on
Your model is actually a 911. Roper (Whirlpool)
The F2 error code is
E0 - Shorted keypad (also called touch pad)
E1 - Keypad cable unplugged
E5 - Cancel key drive line open
E6 - Cancel key drive line open
Solutions:
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Jul 30, 2011 | Ovens
M# 911 4288816 s# OV609596Q showing a F-4 code...what does this mean?
F4 is an error code that flashes on Kenmore electric ovens when the oven's temperature sensor has shorted. You should check the wiring harness and replace the sensor if necessary.
Hope helps.
Rea
Jun 08, 2011 | Kenmore 41389 Electric Double Oven
My start button on my kenmore built-in oven w/microwave won't wor
my kenmore model number 911-47699100 oven doesn't work. Everything except the oven and broil works--cleaning, all timers, start button, etc. All that happens when you push start is about every 30 seconds, two relays can be heard making and breaking kind of like a click then immediately a clack. No error codes appear. Replaced sensor but that didn't work. Any help would be appreciated.
Mar 30, 2009 | GE JKP30WMWW 27" Built-in Single Electric...
Need a new ignitor for a gas double oven
Go to www.searspartsdirect.com and enter in your model number then work your way to the ignitor .. but here is a link if you want a little shortcut there
Mar 29, 2009 | Ovens
Kenmore Double 27" Electric Built-in Wall Oven W Manual Logo
102 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
