Question about JVC Televison & Video
JVC dr-mv5 Records but only plays back audio VCR works DVD works But no picture after recording. No remote.
    Master:
  • 410 Answers
Make sure video plugin is in the right yellow video jack you have video in jack and video out jack if you use rca plugins
Posted on May 21, 2015
2 Suggested Answers
  • 5190 Answers
SOURCE: jvc dvd/vcr player records from vcr to dvd but
Have you finalized the DVD in question? Unfinalized discs usually won't play in other machines. Is the DVD type compatible with the other dvd players? (Some may not handle DVD+R for example; it is an acceptable disc for the jvc DR-MV79.) Try a different brand and type of DVD. Check your other players supported discs.
To Finalize the disc, Menu > Setup > Disc Setting > Finalize (if needed set Disc Protection to Off).
I hope this helps.
Posted on Dec 25, 2010
Testimonial: "that was great so simple yet so important who knew you had to finalize after you told the dvd recording to finish "
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Tip
Well, My JVC DR MV1s is reading and records my DVD-R but it stop reading and...
The most common mechanical problems that can prevent a dvd player from playing or reading the discs are the following:
1. The spindle motor not functioning properly (this is by far the most common, if the spindle motor is not spinning the discs then the optical lens can not read them). For the most part it is an cheap part to replace averaging around 25-35 dollars if you can replace it yourself. If you do not know how and have to take it to a repair shop expect to pay 50-75 dollars in labor depending on the area you live in. The best thing is to do some comparison shopping and call the different repair shops and get estimates. The key is to listen closely when you insert the disk into the player, you should be able to hear it spin up. If you hear nothing then that is most likely the problem.
2. The tray could be out of alignment. This is another easy and cheap fix if you have the proper tools. This could happen if you drop or pull/push to hard on the tray (which you should not really do anyway, but always use the open and close button). This is an example picture of the drive assembly with the tray open.
3. The small gears are plastic and often break, this will cause the players other parts to not move and function properly. They are difficult to reach, but inexpensive to replace. It is always recommended that you always order any part from the manufacturer of the device. A visual inspection is usually required to determine if the small teeth have been broken, which requires for the most part taking out the carriage assembly.
4. The small belt drives either break or come off. Again, this will cause the other mechanical parts not to function. They are difficult to put back on as well, so you may need an extra pair of hands if you have not done this before. On average you will usually have 2-3 of them inside your player.
5. The Optical reader has malfunctioned. This is the most expensive thing to replace, so you might consider purchasing another player depending on how much you want to spend and the original cost of the device, unless you can find a great deal on the part you need. You can check to see if the laser is firing with a visual inspection (DO NOT LOOK DIRECTLY INTO THE LASER) put in a disc with the case off and you should see the glow of the laser hitting the disc. You can also see the spindle/spindle motor.
Picture of the optical reading assembly dismantled:
6. The tray also has a drive motor which can fail and cause the cd tray not to open and it also has a track that it rides on (located in the drive assembly). Check these two components if you are having problems with your tray not opening and closing properly or stops working completely. Sometimes, the tray will open and then immediately close on it's own. This is usually caused by the track being dirty or some type of debris is lodged in the track. Cleaning the inside of the player with a can of compressed air will help remove dust and dirt. Blowing out the inside of the device once a month is a good preventative maintenance measure.
CAUTION: When working with any electrical device, you should always ensure safety first. Make sure that the device is turned off and unplugged from any power source. This does not completely prevent electrical shocks because Capacitors will hold an electrical charge for some time even if the device is turned off and unplugged.
The following are example pictures of what Capacitors look like:
on Sep 24, 2008 | Philips DVP5140 DVD Player
Problem with DR-MV5S JVC Recorder
No! that should not be a factor, there are any number of reasons the VHS is not working, broken belt, idler assembly issues to name a few, I suggest a professional.
Mar 08, 2012 | JVC DR-MV5S DVD Recorder/VCR
I received a JVC DR-MV80B DVD/VCR combo and the DVD's play fine, but on the VCR side, the video doesn't play - only hear audio. Is this a product issue, or something that can be repaired without costing...
Try cleaning the video heads - assuming you got a 'snow' image with audio, see if it helps. Otherwise the VCR might require a head replacement/mechanical realignment, which could be expensive/uneconomical.
Mar 19, 2011 | JVC DR-MV80B DVD Recorder / VCR Combo
Jvc dvd/vcr player records from vcr to dvd but only plays back the dvd on the jvc DR-MV79 won't play on any other dvd players
I hope this helps.
Dec 25, 2010 | JVC Televison & Video
Region free DVD code for JVC DR MV5 VHS/DVD combo
Why don't you just go get another DVD that plays all region.
Its pays. It is not certain that you will get the code for free. I have done a little research but seem not to find any code for your player.
To save your self the stress, get an all region DVD player.
All the best.
Jan 06, 2010 | JVC DR-MV5S DVD Recorder/VCR
I have the JVC DR-MV5 VHS/DVD Recorder and I have recorded the VHS tape onto the DVD. I need to finalize it so it will play in other dvd players, but I can't get a menu to allow that. Help!!
1 Dvd slider should be on DVD.
2. Press SET UP to access main menu
3.Press left and right arrow keys to select DVD SETUP then press down arrow
4. Press left and right arrow keys to select UTILITY
5. Use arrow keys to select FINALIZE
Apr 23, 2009 | JVC XV-N322 DVD Player
Some blank DVD+R discs will not read on my DVD player
The JVC DR-MV1S DVD Recorder / VCR Combo does not suppport DVD+R, only DVD-R, -RW etc.
At least mine only supports these formats, as when I first bought mine, I got some blank DVD's they were DVD+R.
I recorded a movie onto one on my PC, then tried playing it in the JVC unit... no go!
Instruction manual (available for D/load online) proved to me that I could not play +R disks!!
Jun 11, 2008 | JVC DR-MV1S DVD Recorder/VCR
JVC DR-MX1S
This machine has a lot of problems. One thing that often works is to turn it off and unplug it for a couple of minutes. Then plug it in again. Then it will say "loading" for quite a while. Leave it alone until it turns itself on. Then it should be okay. If the couple of minutes doesn't work, sometimes unplugged overnight (same method) works, but then you have to reset everything.
Feb 02, 2008 | JVC DR-MX1S DVD Recorder/VCR
Televison & Video Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
