Question about Microwave Ovens
Where can I purchase handle for microwave model jvm1340ww002
  • Microwave Ovens Master
  • 932 Answers
GE Microwave Model JVM1340WW02 Handle Parts
Lanetha,
here is a link for an online parts place. Hope this helps!
Posted on Apr 28, 2015
5 Suggested Answers
SOURCE: BROKEN HANDLE FOR GE MODEL JVM1340WW002
Odd that we both have the same problem on the same model and same day..
If it's completely broken off, then you have probably pulled the threads out of the cheap plastic,, there are two screws that hold the handle on, one is easy to find/see, on the inside of the door, upper left corner,, to find the other, you need to remove (gently/carefully) the plastic bezel,, (all of this stuff is on the inside of the door), tap on it to find the plastic part,(bezel) and gently remove it by prying,, "prying" is an ugly word,, but since it snaps in, I'm not sure how else to tell you how to do it,, (Just go slow)
Once the bezel is removed, you can get to the other screw,
Now you have both screws, and know where they are supposed to fit later,,
On the back of the handle, the part that goes against the door, there are "studs" (plastic posts about 1/2 inch long and about the size of a pencil),, look closely into hole in the mounting stud, and you will probably see where the plastic threads have pulled out,, If thats the case,, the fun starts,,,
Go to lowes, or Home depot, and buy the smallest bottle of "Loctite" brand epoxy you can find,,
Look closely and the box will say something like,, "SETS IN 5 MIN.", or so,, get the LONGEST setting epoxy that they have,,
Now your back home and drinking a cold beer,, and ready for fun,, ---,Spray the screws with "non-stick" cooking spray, and set aside, (but handy)
Next,, match the handle back up to the door,, and identify which is the top,, mark it,, (masking tape and magic marker),,
I know it sounds silly, but you don't want to be fumbling around with it, while the epoxy runs back out of the holes and all over everything,, set the handle aside, but handy,,
Follow the instructions on the box, to mix the epoxy,, (work quickly)
Now,, using a toothpick or something similar,(disposable) dribble the mixed epoxy into the holes, (where the screws need to go), you don't need to fill them up, but a good 5 drops or so at least,,, WORK QUICK,,, remember to put it in both holes,,
Get ready to mate it back to the door, handle in one hand, a screw in the other,,
Top on top,, and from the front,,put the studs into the two holes
and as quick as you can, insert the screws,, you probably won't need to screw them in, (Threads are stripped out), but you may,, if so, just barely tighten them, just enough to "seat them, and the handle to the door,, It would be best to tape the handle in place until the epoxy sets,,
Check for ozzing,, dribbles, and drops,, and wipe it up now,, or it will be there forever,,
Sit back, put feet up, drink the rest of the beer, and watch epoxy dry,,, (Wait an hour to be safe) Besides, it gives ya more time to drink some more beer,,
Thats my best guess on how to re-attach the handle,, But I'm waiting until tomorrow to do it,, (out of beer)
Best of luck, Ted
Posted on Jan 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken Handle on GE Spacemaker XL
It looks like the current part number is WB15X335.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE model JVM1340WW002 My microwave was
I would say this is is a problem with the bottom door switch.
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There also should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Posted on Aug 24, 2008
  • 105 Answers
SOURCE: Need a handle for microwave
if you go to the site below they show the part you are looking for....
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1340WW02&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&componentDescription=CASE,%20DOOR%20&%20CONTROLS&documentId=E2135008&backToLink=Return%20to%20Sub%20Components%20list
if you have a sears near you call and ask if they have the part or can get it saving shipping costs. if not the correct one you can try this site...
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
on these sites you can get the cost of the parts so you can see if worth the price.
hope this helps you.
Posted on Dec 04, 2008
Spacemaker XL JVM1340WW002 Exhast Fan does not turn off (ever). Light not effected, Door open/closed makes no difference.
Hi, you have a faulty control board as a result of a stuck relay on it which makes the fan to run continuously. The solution is to replace the control board....
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
PLASTIC AROUNG SCREW POINTS HAVE BROKEN OFF AT BOTH TOP AND BOTTOM. HANDLE IS 9 3/4 IN LENGTH AND FITS FLUSH AGAINST DOOR (DOES NOT HAVE A SMALL PART THAT STICKS INTO DOOR . MODEL # J VM230WL01 WANT TO...
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided. The part number for the model number you provided is WB15X322. You can view an exploded view of your microwave door here:
http://pcappliancerepair.com/model-display.php
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
If you have any questions, please post back and let me know. I hope this helps you
Apr 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am trying to replace the door handle. How to I
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave seems to be stuck on delay
thats what the express does its a one button start it
there s nothing wrong with the unit it is doing exactly what is programmed for what you are pushing
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need a handle for microwave that is 1996 model, model # is jvm1340ww002 serial # is vr942153s this there such a thing out there? Ann
Dec 04, 2008 | GE Microwave Ovens
I need a filter for JVM1340WW002 microwave by GE.
You jerks !
I ask for specific help and your site is just a way to get names to offer plans. What a crock.
Nov 16, 2008 | GE JVM2050 Microwave Oven
Light inside microwave dos not illuminate
bulb to be replaced with same similer, if it is not available please get me touch, 9791055855, india, The bulb cost is Rs: 125.00
G.K.Mahendran
Aug 01, 2008 | GE JVM1340AW/BW/WW Microwave Oven
prototech@usa.net
May 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
