Question about Philips Televison & Video
I cannot put my Toshiba TV on Channel 1 since I am with Air TV. How can I set up my universal Philips remote control?
I am receiving some channels through air antenna and as such, my TV does not stop on Channel 1; it goes 4-1, 4-2, 4-3, 5-1, 5-2, 7-1, 7-2, 7-3 and so up to 51-1 and 51-2. The manual says I have to manually put Channel 1.
  • Philips Master
  • 1,103 Answers
SOURCE: AUTO PROGRAMMING T.V.
Your TV is in Showroom Mode - to change:
Menu>Picture>Mode>Power up>Home
Then go back and autosearch channels.
Posted on Feb 09, 2008
SOURCE: PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Posted on Sep 29, 2008
  • 399 Answers
SOURCE: TV stopped responding to remote control
shut off the tv directly from the main power outlet.remove the plug from the outlet.also change the remote batteries.and reinsert the wire after 10 minutes.and check it will work as normal.
thanks.
Posted on Oct 12, 2008
  • 90 Answers
SOURCE: Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Posted on Jan 31, 2009
SOURCE: Element TV remote control
Our Vizio TV came with the same problem and my husband just figured out how to fix this... Go to menu then TV at the top and go down to skip channel. Uncheck all boxes and this should solve the problem. Hope it helps.
Posted on Apr 18, 2009
Need code to program philips universal remote
most philips universal remotes have the "code search" option this is done by:
1: Manually turn on ur tv
2:hold setup untill red indicator stays on and release button
3: press and quickly release what you wanna program (i.e tv,vcr,ect.)
4:press channel up repeatedly untill your t.v changes channels(up to 300 times) if you over shoot the channel change press down til it changes again.
5: press and release MUTE to install the code.
Jun 17, 2009 | RCA Universal Remote Control
Philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Jul 29, 2008 | Philips Televison & Video
I lost my remote codes
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Need codes for a philips universal remote code sheet
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
Codes
Hope this helps :)
Jun 04, 2008 | Philips Universal PH301S Remote Control
Philips remote codes
Hope this helps :)
May 25, 2008 | Televison & Video
Remote codes for philips universal
Hope this helps :)
May 14, 2008 | Philips Universal PH301S Remote Control
Philips universal remote codes for symphonics tv
Manually turn on the device you want to control
1. press and hold the CODE SEARCH button til the light stays on release the code search button
2. Press and quickly release the desired button ( TV, DVD, etc ) the red light blinks off once
3. Press the CHANNEL UP button repeatedly ( up to 300 times ) til the device changes channel and stop
(the red light will blink off after each time the channel up button is pressed )
4 Press the MUTE button to set the code
hope this helps
Nov 23, 2007 | Televison & Video
Televison & Video Logo
105 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
