Question about JVC Audio Players & Recorders
What's your question?my jvc ca-dxt99 theater system don't want to go on. What can I check to fix it myself
3 Suggested Answers
  • 3 Answers
SOURCE: my dvd theater system has no color
some times the dvd's change by itself to PAL/NTSC system so you need enter to set up and select the option in system tv NTSC for America users. Make shure conect yellow cable in the yellow conector.
Posted on May 25, 2009
  • 22 Answers
SOURCE: Connect IPOD to JVC TH-M505 Theater System
http://www.superwarehouse.com/Cables_to_Go_iPod_Audio_Cable/35508/p/1492128
the above cable will allow you to plug your ipod into the audio in on the stereo
Posted on Jun 13, 2009
JVC EX-A1 power failure
Check the main Power fuse inside the unit...
Jan 21, 2013 | JVC EX-A1 System
Hi, I have JVC CA FSY! and it has static noise on speakers but its ok on headphone. How can I solve this problem?
http://books.jvc.com/booklist.asp?Model=fsy1
Choose your submodel.
So the good news is that the amp isn't implicated but an electrical conductor somewhere in the path may be flaky.
Headphone insertion mechanically disconnects output to the speakers. Hence, headphone removal relies on spring-loaded contacts to restore the output to the speakers. Perhaps there is oxidation on the normally-closed contacs. Repeated headphone insertion/removal MAY help wear it off.
Also try swapping the speakers (wire and all) to see if the static follows or stays with the amp channel.
Jul 12, 2011 | JVC FS-Y1 Theater System
Need User's manual for CA-DXT99
Here's a site where you can download the User's manual for CA-DXT99. You will pay $11.50 prior to downloading.
http://www.techrepairs.org/sm/index.php?itemid=33603&AUD_JVC_DXT66,DXT77_&_DXT99
Oct 30, 2010 | JVC Audio Players & Recorders
I have a JVC Th-c50 Home Theater It holds 5 cd's, or dvd's my grandson decided that it should hold 8.. I removed them all, now it shows no disc when loading?? It it expensive to have this repaired or what...
check all internal cables again, may be you turned over the flat ribbon cable to the loader. Check if all the cds is loading ok, that there is no mechanical blocking underway.
Sep 03, 2010 | JVC TH-C50 System
Unlock dvd region jvc ca-dd8
After getting clarification from Fixya I can pass the links below to you to check yourself
Some players are harder than others to do this but you may want to
try here or here
Comments:
Toshiba's and JVC's are the harder ones to do
I use a Phillips myself as it is not only cheaper but has much more going for it than many of the higher end units. i throw anything at it and it just plays
The older the unit that harder it is to do the region free thing with.
I let my EX have the panasonic (big grin)
If you cant find a fix then look at the codes available for cheaper brands and how easy it is to do it before you purchase one.
Just a thought.
Sep 18, 2009 | JVC DD-8 System
Running my tv sound though the home theater
Depending on the type of connection your TV has, you would either connect RCA type cables or an HDMI cable from your TV to the Samsung unit. If you hook up and still don't get any sound, check you cabling ti ensure it is plugged in the correct way. If you don't have the manual, you can go to the following URL to get one:
http://www.samsung.com/ca/consumer/detail/support.do?group=audiovideo&type=hometheatre&subtype=hometheatresystems&model_cd=HT-BD1250T/XAC&mode=C
Jul 10, 2009 | JVC THG31 Theater System
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
Sound from one speaker but not the other
may be power ic one channel failed
Mar 29, 2007 | JVC TH-M505 System
65 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
