SOURCE: 1990 toyota camry
Well if it is a 4 cylinder the timing marks would be small hole in camshaft lined up with little dot on head at 12 o'clock position and the crank with the pulley on should line up with 0 on the timing indicator. If it is a 6 cyl then the marks would be- camshafts both with dots up and lined up with indicaters on heads and crank timing mark on 0 with the harmonic balancer installed. Hope this helps.
SOURCE: 2004 TOyota Camry LE 2.4 ENgine Code is P2238
P2238 = "O2S 1/1 positive current ckt low"
check O2 sensor for degraded performance or wiring to O2 sensor
SOURCE: Maintanance light on a 2007 Toyota Camry LE
Push and hold trip button on dash with key off, turn key on but don't start, odometer will clock down, when it is finished, lite will go off
SOURCE: REMOVING STARTER ON 1994 TOYOTA CAMRY LE
The starter is found under front end.. Near where the moter meets the trani - you will see the flywheel (a big round gear) the starter connects to the flywheel to turn the motor..
Disconnect the battery..
Disconnect wires from starter..
Should be 2 bolts that hold the starter in - remove them..
The starter goes in only one way so you cant mess it up..
Rate well ;o)
SOURCE: 1998 toyota camry le 4 cylinder How do you set the
Just make sure the timing belt is on properlyy, lining up the cam and crank in proper position to each other. The engine willstart when fully assembled because the electrical has not be altered. If it has a crank position sensor , be sure to put it back on after cleaning it and the connector.
