Question about Cell Phones
HOW COULD I CHARGE IT IF THE CHARGING PORT IS NOT WORKING WHAT COULD I DO TO IT TO CHARGE THE PHONE
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
Try using a different charges, sometimes the cables wear out.
Posted on Apr 28, 2015
Samsung sgh z230 charging problem .. plsese help brother
Hi,having charging problem with your phone,you might not be too sure where the problem is really from, you will need to look out in two directions.
!.The charger your using,
! The charging port of the phone.
The charger might not be working properly and will not allow you to charge your phone properly.
You can use another charger to test if it will charge properly.
Also when you check the charger and it's working, You might need to replace the charging port area.
The charging port is the port that you insert you charger into the cell phone.
When you check those two out,am sure you will find a solution.
Take care.
May 25, 2011 | Samsung SGH-Z230 Cellular Phone
My xperia is nt getting charged
The charging port of your phone should be the cause of the problem. It's either the charger is not contacting the charging port well enough or the charging port might be defective and needs to be replaced.
Use a pin to scratch the surface of the charging port and try again. If that doesn't work, then know for sure that you will have to replace the charging port.
If you feel you can do the replacement yourself let me know when you get a charging port replacement so that I can direct you.
Lastly, try another charger first, before you attempt to replace the charging port..........
Good luck....
Mar 21, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Please help - my phone won't charge at all when i plug charger in (i have 2 chargers and neither works), however the headphones work perfectly. what is the problem ? thanks - avril
Good luck.
Mar 21, 2011 | Sony Ericsson Walkman® W995 Cell Phone
1108notcharging
Hi, when a phone does not charge, Usually is either from the charger or the charging port of the phone that is bad.
Use the charger on another nokia phone to see if it will charge. If it does charge on another phone, that means the charger is working,but the charging port is not.The charging port is located below the phone where the charger is been inserted.
It"s very easy to replace.when you unscrew the phone,remove the phone board,the charging port is removable,just buy another charging port,and replace and you are done.
Take care.
Oct 05, 2010 | Nokia 1100
My phone won't charge
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if the charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Sep 14, 2010 | Motorola Mobility RAZR V3
Charging fault
Phone not charging.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 31, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Charging not working
Have you try to use a similar charger to charge the phone to see if it will charge, if you have and yet, he phone is not still charging, the problem is the charging port on the phone, you will need to replace the charging port on the phone because it is bad and can no longer charge your phone.
Go to any local phone repairer to help you replace the charging port on your phone, this will cost you less than $4 to get it replace.
Take care.
Jul 20, 2010 | LG Sprint Fusic LX550 Cellular Phone
LG VX9900 IT WILL NOT CHARGE I THINK THE CHARGING
Hello
Before you conclude that its the charging port i think you need to test another compartible charger and see if it works or you could open your phone with a phone screwdriver and dust the charging port and try it if it works.If it doesn't work then you would need to replace the charging port.Temporarily you can use a desktop charger to charge your batterywhile the port is being replace.
GOODLUCK
Jul 03, 2010 | LG enV VX9900 Cellular Phone
Phones won't charge
hi,
have tested the charger if it is working?
if you test the charger with another phone and is working perfectly then the charging port of your phone is bad.
the charging port is the port where you insert the charger.
try and get a new charging port and replace with the bad one, the phone will charge.
thanks for using fixya.
Jun 06, 2010 | Panasonic KX-T7885 Cordless Phone
Charging problems
try the phone with another charger, if it still does not work, then the problem is from the charging port of your phone.
You need to replace the charging port and your phone will charge again.
Before you repair the charging port, you could use a desktop charger to charge your phone battery so as to keep your phone going pending the time you replace your charging port.
I will you all the best.
Jan 11, 2010 | Nokia 3110 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
