Question about Toshiba Office Equipment & Supplies
I'm working on a Toshiba c281 I need to know how to remove the drum.
  • Toshiba Master
  • 628 Answers
1. Open the front cover
2. Remove waste toner box
3. Remove developer unit
4. Put down the power switch actuator
5. Remove screws (2 special screws can only be loosen) and pull out the process unit
6. Separate the transfer belt from the process unit
7. Remove the main charger unit and u can change the drum
Posted on Aug 20, 2015
I have a toshiba 166 copier,in my print page i have several vertical ghost black line,every thing i do but that's not removed,i cleaned charger wire,and drum,blade,but i don't whats the problem?
that is caused by a drum or Main Charge Grid ,fuser.. check the fuser unit and verify that there are no visible wear marks on the Teflon roller... if not it would be comming from the drum unit (photo receptor) or Main Charge Grid needs replacing? cleaning
May 03, 2014 | Toshiba Estudio 166 Digital Copier Machine
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
Can a scratch be removed on the drum that gives a black line on the print. While cleaning the machine something touch the drum and created a line. TOSHIBA STUDIO 160
Hello
Unfortunately the scratch on the drum cannot be removed, as the drum is a organic material.
The drum and drum cleaning blade will have to be replaced.
Regards
May 09, 2011 | Toshiba e-Studio 161 Copier Copier
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
Inherited Konica 7145 left by last tenant. Powered it up and I get the message F-26-1 Please call Service. (Not sure if this is why they left it behind). Any clue how to resolve this, so I can see if this...
Hello, Paul.
That error code indicates that there is toner/starter spilled onto a sensor near the drum. It might just need to be cleaned. This sensor monitors the drums ability to develop a image.
If the cleaning does not work, it might be a sensor or the drum. The drum needs to be removed to clean the sensors.
Drums are prices around $200 (USD). Various sensors are prices $30 - 180 (USD), depending on which one you need.
Hope this helps.
Mar 14, 2010 | Toshiba 2060 Copier
The getsetner drum was left out over night and now is "dry"
may i know whats you copyprinter model?
do some force in simolation to pump ink on to the drum so that master will stick to the drum
Sep 15, 2009 | Gestetner Copier
Cp error code in toshiba
the error code CP indicates that the Main Motor is locked,
**** do not try any of this while the power is plugged in****
****Do Not touch the surface of the drum and do not leave it exposed to light****
Try:
  • opening up the copier and look to see if the fuser unit (under the red cover) is not melted together.
  • if you know how remove the drum and developer unit. (please ask if you need instructions on this) check that everything in there turns freely.
Please let me know if this helps or if you need further help / any parts for this model.
Dec 16, 2008 | Toshiba 1370 Black and White Copier
Toshiba E-Studio 35 PM Kit Instructions
open front door and remove waste toner container, unplug connector and loose blue screw slide out developer unit removed top cover empty developer(100%). then open by-pass, duplex and jam access cover , remove two screws and slide out drum unit .remove charge corona. release latch on rearand remove bracket/bar( on top of drum),turn level counter clockwiseto release slide drum shaft out.remove two screw lift drum blade before install new drum & blade needdust some lubrication powder.after put everything back,hold down05 while turn onthen enter200,press start,let run about 3 minutes ,the value should bebetween 2.35-2.45 press set or interupt key same procedure doing 08then401 set to 0
Dec 15, 2008 | Toshiba e-Studio 35 Copier
NEW DRUM
joe, to replace the drum, you need to remove the cover from the front of the drum unit it has three locking tabs,one removed,take main charger/grid unit out,located on the top of drum unit,two screws one on each end. the drum is held in with a cam lock shaft located on the front of the drum unit,turn it couter clockwise,your drum can now be removed,it's recomended that you replace the cleaning blade also,two scews. you'll have to coat the new drum with toner and manually turn it against the new cleanig blade,if you dont the blade may flip and ruin your new drum.reassemble
May 01, 2008 | Toshiba e-Studio162D Copier
47 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
