Question about Vizio Televison & Video
My Vizio smart tv 65" screen image turns negative when I switch to any HDMI port but when I switch it back cable TV the picture is normal. How do I fix this?
  • Vizio Master
  • 5,631 Answers
Something wrong with your HDMI port. Check at TV tech service or claim warranty if new
Posted on Apr 28, 2015
HDTV GURU
  • 261 Answers
SOURCE: Sony Bravia KDL52XBR5 picture blanks out using HDMI port
I think this has to do with the cable box not liking the encryption thing going on with the sony tv. The cable boxes probably don't understand it fully and therefore you have intermittant problems. I would just use component inputs. Which are analog and no encryption problems. I hope this was helpful. I bet it doesn't happen using a sony DVD Player or a blue ray DVD Player either. Sony, Sony, Sony.....Good stuff...but they have their moments. Let me know if u come up with a fix for this and then i will post it on my fix it list.. Thank you again..GURU JAY
Posted on Feb 08, 2008
  • 125 Answers
SOURCE: Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Posted on Mar 14, 2009
  • 90 Answers
SOURCE: philips 42" HDMI connection to VGA on laptop connection problems
why dont u just use the vga input and select vga from your input selection. it should work just fine. if not, email me back.
Posted on May 25, 2009
  • 92 Answers
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
Posted on Dec 04, 2009
SOURCE: Toshiba 32AV500U HDMI issues
The Toshiba 32AV500U cannot display 1080p. Hook up your PS3 to your computer monitor, provided that it can display 1080p, or some other TV that can, then change your Video Output settings under Settings> Display Settings and uncheck 1080p, which will allow the PS3 to display in 1080i. Once you do that, then hook up the Toshiba via HDMI and it will work with no problem.
Posted on Feb 21, 2011
The hdmi port of my vizio e231-b1 smart tv is not working. It displays either "No Signal" or "Not Support!" How can I fix this?
That message tends to result from a bad connection (perhaps the hdmi plug in the tv) or a source that does not comply with hdmi standards. This can often be the case when using a computer or gaming device for the signal source. Find a known good signal source and test, then if you still don't get a picture, switch the cable to hdmi 2 and try that one. Ports can go bad or wear out or get debris in them. Good luck.
May 07, 2017 | Vizio Televison & Video
Watch TV (Vizio smart Tv)with my projector (Optoma ML 500)
you cant connect a projector to the hdmi on a tv,you have to connect the cable box to the projector
Jul 03, 2015 | Vizio Razor Led M650vse - 65 Class 64.53...
On my LT42HVi with HDMI input source, the image comes through with a lot of green then will change back to normal color. Switching cables or HDMI input port makes no difference. Using normal TV inpu
is the normal tv input for high definition? Don't understand that term. I have a dish receiver, when I use an hdmi cable I get a really nice picture even with Roku
Jan 02, 2015 | Olevia LT42HVi 42 in. LCD Television
Out of no where my Vizio won't show cable, Blue Ray, or shows on Roku. One of the HDMI ports hasn't worked well for awhile so would have to switch HDMI ports to watch Roku or Blue Ray, but overall worked...
you may need to change the HDMI board in the tv. it will be the hole board the parts are just to small to replace them all to get the HDMI board working again. find a second hand replacement. should be fine with another known working one.
Sep 21, 2013 | Vizio Televison & Video
How do you connect vizio dvd to insignia tv. We r using hdmi cable and NOTHING is happening
If you are using an HDMI cable that is all you need, HDMI is capable of transmitting video and audio to your TV. So the only thing to do now is to get your tv to switch to the DVD player from its normal TV signal. On your TV's remote control you should see a button called 'input' pressing this will bring up a menu of all the possible forms of input on your tv, most modern tvs will have at least 3-4, there may even be several HDMI inputs, the one you need should be labeled on the back of the tv or wherever you plugged it in, but the easiest way to figure out which it is, is to start a dvd playing, then cycle through the available inputs by pressing the input button on your tv's remote repeatedly until you see the picture on screen. (give each a few seconds before switching to the next, as some tv's do have a slight delay before displaying the image).Then make a note of which of the HDMI ports it is for future use.
Hope this was helpful.
May 31, 2011 | Televison & Video
Can't obtain picture on my Vizio VW22LHDtv10T after cable installed between the Dell 15 pin port and the 'pc in' also 15 pin on back of this TV monitor. Do I use the HDMI port on back of this monitor to...
Normally you need to switch the video output to the 15 pin video port by pressing and hold the FN button and then press the one of the Function keys that has screen symbol on the key.
This will toggle the video out put between the notebook's LCD screen and the video output port.
Jan 11, 2011 | Dell Inspiron 1525 Notebook
Motorola DCT6412 III and Vizio VW32L HDMI
After troubleshooting over the weekend, this ended up being the HDMI ports on my Vizio TV. Going to have to take it and get them fixed.
Aug 21, 2009 | Arris DCT6200 DTV Receiver
Vizio Model#:L37HDTV10A After unpluging the HDMI cable & reconnecting it back, I don't have no more HD picture. The Component cable & HD antena works but no HD brodcasting with HDMI connection....
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
May 11, 2009 | Vizio L37 Television
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Televison & Video Logo
69 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
