Question about Maytag Dishwasher
Why won't it stop washing?
Had to drain and stop. It's barely 2yrs old
Mvwx600xw0 wont drain and spin
The out of balance is why it does not spin. You can manually stop the machine, and spin the basket. Then move the clothes until it is balanced. Then start it again on rinse & spin or drain & spin as appropriate. When you get tired of this, try below.
Or you can change the "Soil Level" to heavy or very heavy". This increases the water level and helps it balance the load.
Dec 28, 2012 | Maytag Bravos 3.8 Cu. Ft. Washer
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Kenmore 417-48102701 front end loader washer. Won't go into spin cycle? Any thoughts of what to look for?
could be a number of problems,but try this FIRST push and hold any two buttons in for about 20 seconds make sure the machine is on,if this fails then you could have a blocked pump ie a sock is the usual suspect some mackines have a filter at the lower front check below the door if there is one then open and unscrew anty clock wise,if not then the pump will need removed and unblocked.adrianxxx
Jul 24, 2012 | Kenmore 44072 Front Load Washer
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
My washing machine isn't spinning-its only 2yrs
You should give more information. If if agitates but doesn't spin or pump out, it is could be that something has plugged the hose to the pump (sock?) or something has jammed the pump (nail, pin) or the pump shaft is seized. Turn off the power if you are going to check the pump.
Oct 31, 2009 | Washing Machines
Washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Quiet partner III taking over 4 hrs to complete normal wash cycle
ok check how fast the water is draining,,might be a bit slow...onthejob
Jan 20, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Dishwasher Logo
75 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
