Question about Electrolux Washing Machines
Electrolux EWF1090 Frontloader: can program a wash but machine doesn't start when press Start button: door locks red light comes on, no error shown but LED light of Start button keeps flashing
If I press the button again it doesn't even unlock the door, I need to turn off and back on to unlock. Also tried the sequence to reset the controller hold Start and an Option button, turn power on and wait till display starts flashing and self checking. But the problem persists.
    Genius:
  • Electrolux Master
  • 1,585 Answers
Check door inter lock
Posted on May 02, 2015
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
Normal light blinks
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Daniel
Apr 17, 2011 | Whirlpool Dishwashers
My machine is portable. Model: DP840SWPXO, Serial: FS1107915 It was washing a load of dishes. Set at "HEAVY/NORMAL & NO HEAT/DRY". It stopped working between the NORMAL and RINSE ONLY part of...
Hello & Welcome to FixYa
This can be reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
You can clean the drain pump assembly if the problem returns. Please get back to me if you have any other questions.
Kevin
Feb 06, 2011 | Whirlpool Dishwashers
My 323i was stored for 2 years. I am now getting it road ready and the passenger front, and both back doors wil not unlock. can you help?
Hi, try this as it may or may not apply to your model.Get in, open and close the drivers door, put key in ignition turn 2 clicks and take back out again, within 5 seconds, hold the 'lock' button in the middle of the key and press the 'unlock' button 3 times, then let go. Quickly repeat the lock and unlock button sequence on the spare key. All doors should lock and then unlock when it has worked.
Jan 24, 2011 | 1999 BMW 323 Series
Hazard lights have come on but not flicking..Can't turn them off and now can't unlock car when pressing unlock button on keyring. Right rear door is locked and unable to open even from inside
try reseting alarm system.
with key in drivers door, unlock/ hold key over for 30 secs then lock/hold key over for 30 secs then press unlock button on remote
the system is now reset.if windows go up/down you have comfort settings on your computer.nice.....
if rear door still locked you will need to strip it down to find fault.then reset again...
May 24, 2010 | 2000 Audi A6
Need code for durabrand portable dvd player
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Kenmore elite 790.3670 oven door locked
I held down the clear button for three seconds, it unlocked but still showed the lock button lit. It began beeping over and over. I opened the door and pressed the clear button again for three seconds. It stopped and the oven works just fine now. In fact, I used it right after I got it cleared out.
Feb 07, 2008 | Kitchen Ranges
Washing Machines Logo
262 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
