Question about Brother CE8080 PRW 80 stitch Limited Edition Project Runway Computerized Sewing Machine Refurbished Metal
My auto threader fell off
Can i fix it myself
Thread jam above the needle...I'm afraid to pull it from the top as I work the needle wheel manually in case it breaks off inside...
This may be helpful:
Pfixing the Pfaff
Most likely there is a worn groove or a rough spot that has caught the thread. I have an older machine that has an issue and have had to cover the spot with duct tape, although there may be other fixes.
If you are concerned about doing it yourself, just take it to a sewing repair shop and see if they can fix it there for you.
Aug 23, 2016 | PfaFF Sewing Machines
Can I fix a Bernina Artista 630 Y Axis sensor myself?
Have you consulted the owner's manual, SetUp - pg 92 re screen calibration? Try going through the SetUp function again.
BERNINA Support Machine and Accessories Finders and Software Support...
Feb 16, 2016 | Bernina Sewing Machines
Can I replace the plate needle on the singer profinish serger myself
Laura's Blog: Do it yourself serger repair - How to adjust ...
bangerlm.blogspot.com/2007/.../do-it-yourself-serger-repair-how-to.htm...
Jan 30, 2007 - So I recently did something awful to my serger and the needle broke, the ... Plus it isn't really generic, it is basically some notes for some various olderSinger sergers. ... There were two screws on the bottom plate, plus 4 screws in each of ... If you thread the machine and you can't get the lower looper thread ...
How to fix timing on serger - YouTube
? 4:36
https://www.youtube.com/watch?v=BT6kiYyG2bw
Jul 21, 2013 - Uploaded by Jasmine Harris
Up and close detailed view of how to fix timing on your sergermachine ... looper and lower looper should be when the needle is up or down. .... way I can ever take it into the shop, so unless Ican fix it myself I'm out of luck. .... How to fix the upper looper timing on a Singer serger/overlocker - Duration: 11:02.
[PDF]Singer 14CG754 Serger Commercial Grade Manual.
www.sewingmachinesplus.com/media/.../singer/.../Manual_14CG754.pdf
Jan 10, 2016 | Singer Sewing Machines
My foot dog will not pull the fabric as I sew? I'm having to pull it manually myself .. Anyone know how to fix this problem?
How old is your machine? Can you unscrew the feed dog plate and take it apart and oil it? Sometimes if you are doing lots of quilting/sewing it gets all stuffed up with fluff inside there.
Dec 02, 2012 | Elna Sewing Machines
The touch screen on my Pfaff 2056 went dead, what can I do to fix it myself?
Apr 26, 2012 | Sewing Machines
My janome my style has jammed itself in reverse. How can I fix it?
Hi, bettboop
you can check out youtube they have many video's on sewing machine
fixsewingmachines.com--they also have information
Apr 07, 2012 | Sewing Machines
Will not thread the needle automatically, can I fix this myself?
Did fix myself. Saw that some very small 'metal rods' -for lack of the correct terminology- were bent. Straightened them with tweezers. A temporary fix to be sure, but I'm back in business.
Dec 05, 2009 | Baby Lock Ellure
Reverse on my kenmore sewing machine doesn't work. can i fix this myself? can't afford sears $90 min charge. cheaper to buy a new machine and get a warranty if I can't fix myself?
You need a shop adjustment, try not to take the machine into large stores because they immediately put a massive fixed charge on before any work is done on the machine, find a local dealer if possible they will sort it out for probably a fraction of the price
Oct 31, 2009 | Kenmore 11206 / 11306 / 11506 / 11606
Backstitch button broke off. Can I get a
Direct from a Singer agent or from Singer, you should be able to fix it yourself.
Oct 30, 2009 | Singer 3116 Simple
Brother CE8080 PRW 80 stitch Limited Edition Project Runway Computerized Sewing Machine Refurbished Metal Logo
48 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
