Question about Optics
Which is the right scope mount base part number
  • 2,189 Answers
What is the weapon that you are trying to get mounts for and what are the part numbers that you have to decide between
Posted on Apr 28, 2015
I purchased a Mossberg 935 shotgun. I went to put the weaver base on to mount my scope, and when I screwed down the 4 screws on the mount, the front two screws push down on the top of the reciever and stop...
Sounds like your screws are too long.
Put the screws in w/o the base and see if there is a difference between the rear and front screw hole depth. (I think I am understanding your description, I don't have a picture. Picatinny type rail ? )
Grind/cut/buy screws the right length.
Put some purple locktite on the threads when you are ready to bolt it down for the final time.
Oct 12, 2017 | Mossberg Marlin Rifle 992m,989,mossberg...
Elevation adjustments do not seem to hold or the scope moves slowly over time. I'm not certain. Windage works fine. Looked at manual on the web and the scope must have changed design because not...
Most of the time a scope that creeps off its zero, has a loose mount screw and or loose mounting ring. Check the mounts all screws. Some times the opposite is true. The mounts are to tight and in a bind. Then during firing the receiver heats up an tweaks the scope enough to cause creep. If the scope is always on zero when cold and creeps off after a few shots, she is in a bind. Make all adjustments to the scope base and rings with a cold gun. Loosen the front ring screws first then re-tighten then loosen the rear doing the same. Then try and re-zero the gun. If the gun never comes back to zero, you end one day shooting hi to the right and try again the next day shooting in the same spot try to re-tighten all screws. Screws from mount to gun then scope rings to scope body.
Jan 02, 2011 | Nikon 39x40 Matte Nikoplex Buckmaster...
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
Cant adjust windage to the left eneough
There are several potential problems that could be causing this. The most likely are:
misaligned rings
misaligned ring bases
misaligned ring base screw holes
Bent scope
other potential issues
bad scope
bent barrel
poor action bedding (putting enough pressure on the barrel that it throws the bullet to the right, unlikely)
The first 4 are most likely and can be checked by using a different scope. If you have the same issue with the new scope, then look to the rings and mounts as your probable issue.
Sep 04, 2010 | Leupold 66405 Vx3 Rifle Scope 4514x40mm Lr...
Cannot get to the bull's eye. rifle shoots 2" to right of bull's eye. after two full turns left on windage - nothing happened. I',m ready to return to the store. Any help???
continue to adjust the wind-age. If your problem persists I would suggest turning both to a random point and re-start sighting the gun. If that does not fix the problem return the sight because this most likely means the wind-age is disconnected.
Aug 17, 2010 | Bushnell .22 Rimfire 3-9x32 Rifle Scope...
Need a pair of adjustment caps for a Redfield 2x7 Scope Where might I locate?????
go on line with redfield and look for there tech phone number and call them.
Mar 19, 2010 | Redfield See Thru Rifle Scope Mount Base...
How to readjust a weaver mount?
Make sure the nuts are on the same side of the rifle (both on the right OR left). The clamping mechanism can vary the centering of the scope if they are on opposite sides of the mount.
The other problem may be poorly drilled mounting holes on the receiver or scope mount, check these for alignment with your bore or barrel.
Mar 15, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
SWIFT MARK II, MODEL 841 SPOTTING SCOPE BASE
Hi, I would contact Swift directly on this number: For ordering parts or warranty repair information, please contact Swift Customer Service at 800-523-4544. You can get other contact information and dealer locations on their website: http://www.swift-optics.com/support/faq/dealer The 'scope is mounted on a standard camera tripod thread so you can always check your local camera dealer. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Swift Telemaster 841 (15-60x60 mm)
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
