Question about Kodak PIXPRO AZ361 Bridge Digital Camera - 16MP 36X Optical Zoom HD720p -Black
The Screen says lens obstruction, Please restart the camera. How do you restart the camera?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Kodak Expert
  • 305 Answers
Turn off your camera, take out the battery, remove your lens, check for obstructions on glass and connections, replace lens. put in battery, then turn on camera. you should be set.
Posted on Jun 02, 2015
  • Arthur Cowgill Jun 09, 2015
    you cant remove the lens on a bridge camera they are fixed make sure lens cap is removed
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 68 Answers
Press and hold the power button.
Posted on Apr 28, 2015
Get message Lens error, restart camera
Not much you can do. Switching off the camera and then on, is like a cod boot from a computer.
You could try to remove the battery for a few seconds, and then reinsert it. Then you should investigate why the lens stays out. Is it because of a mechanical problem, or came some dirt between the barrel, while the camera got wet? Try to remove any obstruction. feel if the lens can move by gently moving the barrel a little. If it goes. Don't apply force, because you could damage the mechanical or electrical parts in the lens barrel.
I hope it works. Don't forget: the battery should be charged fully.
May 12, 2014 | Canon Cameras
My Panasonic lumix camera model DMC-ZS5 is stuck with the lens out and the screen reads system error (focus). How can I reset it?
To avoid damage, most cameras with retractable lens, will shut down, when while the lens should move (in or out) something is obstructing the movement. That can be a hand in the wrong place, or just a purse, just anything.
If this happens, you should switch of the camera. Then remove the battery, giving the camera a restart after you reinsert the battery (same as a cold boot from a computer)
When after reinserting the battery, the lens returns to the normal place, you are lucky.
If it does not move, it could be a serious mechanical problem occurred, like something broke in the lens barrel, or the lens motor is defect.
Just try what I told, and lat us hope after that you never see this problem.
Success
Mar 02, 2014 | Cameras
My camera says lens obstructed. What does that mean?
Hello, That means the CCD assembly is not transmitting a full image to the cameras internal circuits, needs to be diagnosed and serviced / repaired.
Best Regards, Russell
Dec 25, 2012 | Kodak EasyShare M532 Digital Camera
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Ge c1033 digital camera having problem as when power on camera its lens on and off and shows error "lens Obstruction restart camera" please help me resolve it.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Sep 21, 2011 | GE E1030 Digital Camera
'Lens error please restart the camera' msg displaying
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 28, 2010 | Canon PowerShot A420 Digital Camera
When turning on there are several buzzes and the lens goes in and out then closes and screen reads "lens error!" in red
There is dirt or an obstruction in the lens telescoping mechanism or the lens cover that is preventing it from working properly.
Try clearing it with compressed air.
Otherwise, you need a professional to repair the camera. You can find a service center on the manufacturer's website.
If this helps, please vote for my solution.
Oct 12, 2009 | Nikon Coolpix S210 Digital Camera
RE: Canon solution
It is most probably that your hand was in the way when the lens is trying to come out.
Try restarting and make sure no obstructions are in the way of the lens.
Sep 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Panasonic Lumix DMC-FZ20
The lens can not move due to an obstruction.
Gently put some force on the lens, turn the camera on and it works.
Best regards from Holland!
www.SemafoonWinkel.nl
Jan 07, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Kodak PIXPRO AZ361 Bridge Digital Camera - 16MP 36X Optical Zoom HD720p -Black Logo
808 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
