Question about Vizio Televison & Video
Screen reads "no channels in master list"
Why does it say this and how to I get the channels back
  • 494 Answers
You may have to do a 'search' for local channels in either cable or on-air mode. It is in the set up screen.
Posted on Jun 30, 2015
3 Suggested Answers
spr1949
  • 1182 Answers
SOURCE: uverse says no channels in master list
Do resetting and go for auto scan. If the channels are not stored, there is something wrong with the memory chip inside.
Posted on Jul 30, 2012
terrydovre
  • 181 Answers
SOURCE: How do I add the HD channels picked up my HD antenna to the master channel list on my Visio TV?
Hello, with the set on, press the menu button, move the cursor down till the "Tuner" section is hi-lighted, click on it. Then the first selection is "Tuner Mode" click on it, the choose "Antenna" click on it. Then move to the "Auto Channel Scan" and click on it, and let it set all your channels. when done, just exit menu and change channels as desired. you can go to page 39 in your manual for these instructions: Tuner Mode
Select Cable or Antenna depending
upon which equipment you have
attached to the DTV / TV Input.
Auto Channel Search
Automatically search for TV channels
that are available in your area. Be
sure to first select the correct tuner
mode above. The TV will search for
analog and digital channels. When the
search is done, press EXIT to begin
watching your programs. thanks, Terry
Posted on Oct 09, 2012
My screen shows no channel in master list
mine doesn't either, I use my satellite remote and use the program guide to select the channel I want to watch
Oct 16, 2014 | Vizio Televison & Video
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Auto Channel Search
Oct 09, 2012 | Vizio M220NV 22 in. LCD TV
Uverse says no channels in master list
Jul 29, 2012 | Vizio Televison & Video
No channels in Master List message on Vizio xvt3d554sv with Dish Network Satellite...what to do?
I had this same problem. My TV had sound and the lights were on but no picture. The screen said "No Channels in Master List."Here is how I fixed it:1) I made sure that my Dish Remote was on the TV mode (when pressing down buttons, the TV button would light up).2) Once that was confirmed, I pressed 03 to ensure I was on Channel 3.3) (this was the hardest part!) I found the remote that came with the TV. I never use it so it was hard to find...4) I pressed the Input button and selected the correct Satellite option. On my TV, that option is: "HDMI-1 Satellite"5) The picture was restored!
Aug 19, 2011 | Vizio L37 Television
On bios the primary ide master is reading [pioneer dvd-rw instead of the hard drive
Have you got the DVD and Hard drive on the same IDE channel? You need to set the Hard drive to the IDE master channel (IDE 0) and the DVD to the Secondary master (IDE1) on the motherboard.
This way, if you need to ever re-install the OS you will not have any problems.
The only way , apart from a corrupted bios, that the DVD will read as master is if it is plugged into the IDE master socket.
I'm assuming you have the jumpers set to the master configiration on the DVD and the Hard drive? Schematic on the hard drive will show where it is and the DVD is set to master (looking at the back of it) when the jumper is on the rightmost set of pins.
If the above do not apply , or you have already sussed this, remove the bios battery for 2 minutes and press the power switch (computer unplugged of course) then replace. If this does not cure the problem, I'd download a bios update and flash the bios
Jan 10, 2011 | Sony VAIO VGC-RA840G PC Desktop
The screen has a message "No channel in Master List" on it. There is no picture or sound.
tv is on the wrong input, just press the input button on the remote or the tv that should fix it for ya
Jun 08, 2010 | Vizio P42HD Television
Channel reset in Menu
Change the tv channel to 4 go into the menu and change it back to 3 then put your TV back to 3
Feb 15, 2010 | Samsung DVD-VR320 DVD Recorder/VCR
Televison & Video Logo
100 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
