Question about Refrigerators
Vegetables have been freezing in the veg drawer.I recall theres some sort of maintenance that can be done in the freezer unit any ideas and Can I do it myself?
    Top Expert:
  • Refrigerators Master
  • 52,086 Answers
Turn the temp dial down a little
Posted on Apr 28, 2015
Testimonial: "Ray, Already tried that, not a solution."
  • ray gallant Apr 28, 2015
    then I would call a service man my neighbor had to get the control replaced on their amana last summer they stuck a flat knife in the door till the part came at the back of fridge it controls air from freezer to the frig
2 problems
Do your vegetable keeper drawers have humidity controls?
Jun 13, 2008 | GE Profile¿ Arctica® Energy...
My Whirlpool refrigerator model no. ED5FHEXNS01 lower crisper pan freezes veg. Any suggestions.
I believe there is a air vent / hole .. if you remove the crisper drawer on left you should see a small mechanical vent if so close it.
Jan 23, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Some fruits and vegs freeze in drawers, but not all
GE fidge it is a common problem...air dampers stuck wide open..too much cold air going to fresh food side from the freezer..you need to call repair man
!!! but if you still want to do repair by yourself, send me model number i send you some ideas and most important some images...so you can put everything back together after you done :)))
totalcarefl@yahoo.com
Aug 29, 2009 | GE Refrigerators
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
Apr 14, 2009 | Refrigerators
Follow up to question: meat & veg tray freezing food on new side by sid refrigerator
with very littlle ice cream I would set freezer temperature to -2 degrees and leave the humidity seting where you have it remember to let the unit run for 24 hours to stabilize then you can make another adjustment. By the way you are not being a pest I don't mind helping you at all, I am a service manager and answer quesitons allo day long.
Jan 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Bottom vegetable/fruit drawer freezing fruit
to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
