Question about Whirlpool Dryers
My boy put his weight on the dryer door while taking clothes out of it. Now it won't stay closed, it keeps popping open. The whirlpool dryer is 6 months old, It's not the latch.
  • Whirlpool Master
  • 3,512 Answers
Place dryer on the floor
put car jack under the opened dryer door and gentle lift the door in the opposite direction with the child sitting on the dryer when placed on the floor. Experiment - A little bit at a time test door until latch works again.
Be careful not to damage the door with too much jacking / lifting.
May want to place a piece of timber between top of jack and door to minimize damaging the door.
Posted on Apr 28, 2015
Whirlpool dryer door pops open.
It appears the your door is not aligned like is supposed to due to the weight you put on when leaned on. You now need to do some twisting and turning to bring the door alignment back to normal . When you do this process don't over do it or it may break. If is not possible you may need to replace the complete door or just the door hinge. Good luck
Nov 16, 2013 | Whirlpool Dryers
I have a whirlpool gold dryer. I can't keep the dryer door shut while clothes drying. it keeps popping open.
the problem is the door latch have a look and see if the door pin (plastic) still has both prongs they should look the same from side to side if they are then the tension wires in the doors clamp have come apart. if one side of the door pin has snapped off (most common problem from slamming door closed) replace the door pin
hope this helps
please take the time to rate this repair
Aug 03, 2010 | Whirlpool Dryers
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
Jul 14, 2010 | Whirlpool ET8CHEXSQ Dryer
Dryer door won't stay shut latch won't catch
If this specific dryer has the door that opens forward (top to bottom as opposed to left to right, etc...) the common problem is that downward pressure on the door has bent it slightly. This happened on mine when one of my daughters would lean on the door while loading and/or unloading the dryer. If this is the case, then the door may pop open while running even though the latch looks good.
The best way to tell is just let the door rest naturally in the closed position. If it does not rest all the way closed, then the lower portion of the door & frame has been slightly bent as indicated above.
The door & frame has to be slightly bent/forced back out at the bottom. This can be accomplished with a large screwdriver or something similar such as a paint mixing paddle or basically anything that will fit between the bottom of the door (from the inside) and the dryer frame. Very slowly close the door with the paint paddle or large screw driver in place (again on the inside...not from the outside of the door). The goal is to just barely force the bottom of the door framing back out without warping it grossly.
Just take your time and be as gentle as possible & make small adjustments until the door will remain closed and latched.
The latch is really only required to keep the door secure while clothes are beating against the door interior. Proper alignment actually keeps the door closed.
Let me know if this helps.
May 06, 2010 | Whirlpool LEN2000PW Dryer
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer door won't stay shut when drying clothes
There is a clip inside your dryer door that acts as snap (kinda like on baby clothes). It snaps the door closed - so to speak. If the outer part of that 'snap' gets a little stretched out it will not hold as tightly. When those heavy, wet clothes hit against the door it pops it open because the 'snap' is not working right. As long as the outer part of the 'snap' is still intact, you can fix this problem by simply squeezing it together alittle to make it grab tighter so that the door stays closed while drying your clothes. If that doesn't make it tight enough you could tear off a small corner of a paper towel to fill in the hole a little to make it tighter.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Whirlpool Dryers
My dryer was working. I stopped it to take my clothes. When I went to put in the wet clothes my dryer would not start.
Try pressing on the door to close it and
see if it starts. It sounds like the door switch has failed or the actuating arm is bent. You should hear a click as the door just barely opens or is nearly closed. No click = no start. I.e. Door switch problem.
Jan 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Dryers Logo
99 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
