Question about Bosch Refrigerators
I was moving and the wires have slipped out my Bosch KGV28325GB/05 what wires do i connect to get my freezer to work please family emergency
  • Bosch Master
  • 5,323 Answers
If u connect the right wires to the rright ends they will work fine?
Posted on May 12, 2015
I am requesting a wiring diagram please
then perhaps request it from the manufacturer who by the way you forgot to mention in this question
Aug 24, 2015 | Refrigerators
Fridge of fridge freezer does not get cold (bosch excel KGN34X61GB-05)
Sounds short of refrigerant or very blocked up condenser. Is there a lot of heat from the back/ underneath>
Mar 21, 2014 | Freezers
Only front wipers not working on 2005 expedition
check the linkages at your wiper motor. check the wires for power to the motor.
Dec 28, 2013 | 2005 Ford Expedition
Hi,my bosch f/f is freezing in the veg box and has a lot of ice under the last box in the freezer comp.What is the problem please?
In the back of your fridge you should see a hosepipe connected from the freezer's defrost water drain to the evaporating tray usually located on top of the compressor. The drain is blocked, hence you get ice on the bottom of freezer. The easiest way to clean it is to pull the hose pipe off the fridge outlet and clean the drain upwards with a piece of soft wire or electric cord or something similar. On my fridge (Bosch) I found the drain clogged with a kind of jelly like stuff. The other way to the drain is by removing back panel inside the freezer compartment but be careful, I sort of ripped mine off and broke plastic plugs on which it was fixed. Make sure you know what you doing.
Cheers Karel
Jul 28, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Jul 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch fridge not cooling freezer fine
if back wall of freezer has ice or thick build up you may have a defrost problem or if not the evaporator fan motor could be bad, not moving cold air from freezer to refrigerator.
Mar 14, 2009 | Bosch Refrigerators
Bosch KGU31124 Freezer Not Working
I have the same freezer and get the same problems. Ice forms on the refrigeration fins beind the plastic shroud at the rear and completely blocks the airflow. The fan that moves cool air around does not work then and freezer temp goes up. Ice will often push the shroud forwards so that the door does not close properly. Warm moist air get in and just increases the ice problem.
I take the shroud and fan housing off the rear (4 screws and a wire to the fan) and defrost thoroughly using a hair dryer. You can then see when all the ice has gone..
Sep 18, 2008 | Bosch KGU31124 Bottom Freezer Refrigerator
Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
May 25, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Bosch Refrigerators Experts
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
