Question about Refrigerators
Frig too cold---22 degrees @ less than 1 setting on thermo.
  • John Genovese
    John Genovese Apr 27, 2015
    Hi jake kammerer, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? brand + Model number?
  • Refrigerators Master
  • 5,323 Answers
God is so good:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Posted on Apr 27, 2015
Refrig part got up to 68 degrees inside. Freezer still stayed cold. Why would this happen?
1. Check the setting on the frig. 2. Thermostat on frig may be broken and frig goes to near room temperature.
Sep 01, 2011 | Refrigerators
Frig is turned down to low and everything is still freezing. Ice maker not making ice.
icemaker not working because to cold in freezer;water transfer tube frozen and will need to be deiced, but first must solve refrig. to cold, making freezer to cold, thermostat problem which is common it is a presure filled and in time can loose presure and will run colder, some have adjustment scew with arrows warmer or colder adust warmer and only turn a 1/4 turn or less until you get in middle of dail range. or replace thermostat. refrig. temp. should be 38 to 40 degrees frenhiet. freezer no colder then 0.
Nov 29, 2009 | Frigidaire GLRS234ZA Side by Side...
Frosting up of freezer fan/fan runs continuously
Clean and check the seals around the doors, the unit is trying to compensate for temperature loss.
Jul 27, 2009 | Refrigerators
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
The fridge section is getting too cold at the bottom
THE CONTROL THAT DIVERTS MORE AIR TO FREEZER AND LESS TO RE-FRIG SIDE COULD NEED TO BE ADJUSTED TO KEEP MORE AIR IN THE FREEZER SIDE , MAKE SURE ALSO THAT THE SMALL FAN IN THE FREEZER IS RUNNING , ALSO TURN THE THERMOSTAT CONTROL TO LESS COLD , IF YOU HAVE A THERMOMETER TO PLACE IN FRIG SIDE TRY TO KEEP @ APP 40 DEGREES IN FRIDGE SIDE SEE IF ANY OF THESE HELP
Feb 23, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
Constantly runs and what is the normal frig. temp?
37-39 sounds like a problem check the freeezer coil for frost buildup
May 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side-by-side with thermo switch problem?
Acting like a bad thermostat, One thing to check is make sure compressor isnt overheating. If really hot you could have a relay problem on compressor.
Jan 05, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
