Question about Eureka Vacuums
Where is reset switch on eureka air sp where is reset switch
    Top Expert:
  • Eureka Master
  • 51,518 Answers
Do not think there is one .
Posted on Apr 27, 2015
Where is the reset button the eureka the boss smart vac
There are many different models of Boss Smart vac so I can't say for sure without your model number but it most likely does not have a reset button. It may have a reset switch built into the motor.
Feb 26, 2017 | Eureka Vacuums
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
Can someone please tell me where the reset button is located on the Eureka air speed abs pet?
It should be at the bottom of the unit, near or on the motor housing.
Mar 20, 2016 | Eureka Vacuums
My eureka multicycloning upright won't turn on.
There's a thermo-switch in the motor that cuts out if the motor gets too hot. If you wait 30 minutes it should reset and the vacuum can be turned back on.
If it doesn't reset after 30 minutes, your only recourse is to take it to a Eureka authorized service center for repair, or call Eureka at 1-800-282-2886.
May 30, 2014 | Vacuums
Where is the reset button on my eureka canister vac
with out knowing the model # i can't say for sure. however most of the eureka canister vacuum's ive worked on do not have a reset button. If its not working is probably the cord or switch that has gone bad. hope this helps
Jan 14, 2013 | Eureka Vacuums
Will not start
Check for a reset button on the side of the machine near the brush roller area.You may need a new power switch that often fail after the machines over heat or refer to this DIY vacuum cleaner guide.take it into a eureka vacuum service center
Jun 05, 2012 | Eureka As1001a Vacuum
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Broken on/off switch
I have the same vacuum and the on/off switch wasn't working any longer so I took the cover off to find out that the wiring got so hot that it melted through the wire coating and plastic frame.
Aug 04, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Eureka Bagless Widetrack, The Boss, Vacume, model 5893
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis. It is Part #27871.
Jun 05, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Boss vacuum just quit
You have a clog in the hose (or somewhere) most likely the hose though. Find the clog -clean it out-let the machine cool down and you are back in business. This is really a good feature of the Eurekas because rather than continue to run and burn up the motor it shuts off -you clean it out and your vacuum is saved.
Sep 08, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
105 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
